15 Watt RF Power Amplifier Selection 140-170 MHz
adnan012
Advanced Member level 1
hi,
I want to make a amplifier simulation in ADS. How amplifiers are selected on out put power bases. Suppose i select AFT09MS015NT1. Can i get 15 watts 136--174 as mentioned in datasheet, If the amplifier is properly matched.
It looks like you can squeeze 15W from this device at the required frequencies.
You should ask for S-parameters from the vendor and check stability and matching.
R.
