+ Post New Thread
Results 1 to 2 of 2
  1. #1
    Full Member level 6
    Points: 3,488, Level: 13
    Join Date
    Oct 2006
    Posts
    326
    Points
    3,488
    Level
    13
    15 Watt RF Power Amplifier Selection 140-170 MHz
    hi,
    I want to make a amplifier simulation in ADS. How amplifiers are selected on out put power bases. Suppose i select AFT09MS015NT1. Can i get 15 watts 136--174 as mentioned in datasheet, If the amplifier is properly matched.
    Regards
    •   Alt9th January 2017, 19:01
      advertising
  2. #2
    Member level 3
    Points: 517, Level: 4
    Join Date
    Apr 2016
    Posts
    58
    Points
    517
    Level
    Re: 15 Watt RF Power Amplifier Selection 140-170 MHz
    It looks like you can squeeze 15W from this device at the required frequencies.
    You should ask for S-parameters from the vendor and check stability and matching.
    R.
