+ Post New Thread
Results 1 to 4 of 4
  1. #1
    Junior Member level 3
    Points: 343, Level: 3
    Join Date
    Oct 2016
    Posts
    30
    Points
    343
    Level
    creating a linearly and circularly polarized antenna?
    I would like to know if you have some exemples of small antennas which are both linearly and circularly polarized antennas? and if you can explain to me how we can create both polarizations on an small antenna?
    Thank you
    •   Alt9th January 2017, 16:32
      advertising
  2. #2
    Advanced Member level 3
    Points: 6,008, Level: 18
    Join Date
    Jun 2012
    Edmonton, Canada
    Posts
    944
    Points
    6,008
    Level
    18
    Re: creating a linearly and circularly polarized antenne?
    A circular patch can do both if you have an appropriate feeding method (e.g., quadrupolar) -- but these will occur as a result of different modes being excited, and therefore possess different operating frequencies.
    1 members found this post helpful.
    •   Alt9th January 2017, 17:14
      advertising
  3. #3
    Super Moderator
    Points: 239,577, Level: 100
    Awards:
    1st Helpful Member
    Join Date
    Jan 2008
    Bochum, Germany
    Posts
    41,511
    Points
    239,577
    Level
    100
    A cross dipole can generate all possible polarization variants (horizontal, vertical, left and right circular or elliptical) by adjusting phase and magnitude of both feed lines.
    •   Alt9th January 2017, 17:20
      advertising
  4. #4
    Points: 665, Level: 5
    Join Date
    Apr 2014
    Posts
    27
    Points
    665
    Level
    You can not do both at the same time.
    But you can build antennas were you can switch between linear and circular polarization, best example is a crossed dipole.
    A circular polarized antenna will receive a linear polarized signal fine but with a 3dB loss, same the other way around.
