+ Post New Thread
Results 1 to 5 of 5
  1. #1
    Newbie level 6
    Points: 391, Level: 4
    Join Date
    Jan 2016
    Posts
    14
    Points
    391
    Level
    Load Pull for Differential PA?
    Dear all,
    I am a beginner.
    How to perform a load/source pull for differential PA? Do I need to use balun/transformer?
    Or a single ended configuration is sufficient to extract the optimum impedance then connect it in differential manner to get 3dB extra power?
    Please share.
    Thanks
    •   Alt9th January 2017, 15:50
      advertising
  2. #2
    Advanced Member level 5
    Points: 26,445, Level: 39
    Join Date
    Nov 2001
    Turkey
    Posts
    3,771
    Points
    26,445
    Level
    39
    Re: Load Pull for Differential PA?
    No, you should use Balun.Differential Optimum Load will absolutely different than single ended.
    But later on, de-embedding of the Balun from Optimum Load Impedance will be quite hard because of phase relationships.
    •   Alt9th January 2017, 16:12
      advertising
  3. #3
    Newbie level 6
    Join Date
    Jan 2016
    Posts
    14
    Points
    391
    Level
    I am using Cadence spectre. Do you think I can use ideal balun?
    Thanks
    •   Alt9th January 2017, 16:18
      advertising
  4. #4
    Super Moderator
    Points: 241,412, Level: 100
    Awards:
    1st Helpful Member
    Join Date
    Jan 2008
    Bochum, Germany
    Posts
    41,904
    Points
    241,412
    Level
    100
    In simulation, you won't need a balun, just a differentially connected load.
  5. #5
    Newbie level 6
    Join Date
    Jan 2016
    Posts
    14
    Points
    391
    Level
    If you dont mind, can you show some visual of that.
