+ Post New Thread
Results 1 to 4 of 4
  1. #1
    Newbie level 1
    Points: 10, Level: 1
    Join Date
    Jan 2017
    Posts
    Points
    10
    Level
    faulty gigabyte keyboard
    I recently bought a second hand Gigabyte Stealth gaming keyboard, model number GK-FORCE K7 and from time to time some of the keys, like 't', 'backspace' and other keys do not work. The odd thing is when I plug in the keyboard the '4' key is stroking without me doing anything.
    I am using Windows 10 but tried the keyboard on different OS's with the same results. Opened the keyboard tested the control board for voltages, faulty parts, traces and connectors with no bad one's found. The main IC is HT82A525R and EEPROM chip is T24C02A.
    I am trying to reprogram the EEPROM as soon as I will get the code and see what will happen.
    Any suggestions will be much appreciated.Thanks in advance.
    •   Alt9th January 2017, 12:32
      advertising
  2. #2
    Advanced Member level 3
    Points: 6,313, Level: 18
    Achievements:
    7 years registered
    Join Date
    Sep 2009
    Lancashire UK.
    Posts
    932
    Points
    6,313
    Level
    18
    Re: faulty gigabyte keyboard
    Take it apart, clean all the contacts and around the IC pins.
    Let it dry, test it before re assembly.
    Before you ask - have you searched the forum? Have you searched Google? - Please do so.
    Please do not ask me in private - ask in public. Also please do not ask me to be a forum friend.
    If I have gone to the effort to help you etc then please have the decency to at least acknowledge it and do not just ask a question then never come back..
    •   Alt9th January 2017, 15:59
      advertising
  3. #3
    Super Moderator
    Points: 46,805, Level: 52
    Join Date
    Apr 2011
    Minneapolis, Minnesota, USA
    Posts
    11,668
    Points
    46,805
    Level
    52
    Is it a membrane keyboard? Remove enough screws, plastic, etc., so you can lift up the membrane. Clean all carbon buttons and contacts. Examine in/ around/ under the 4 key, to see whether it has loose carbon, etc., that makes unwanted contact.
    Alcohol is a good solvent to try. Do not use acetone, lacquer thinner, fingernail polish remover.
    •   Alt9th January 2017, 17:04
      advertising
  4. #4
    Super Moderator
    Points: 69,574, Level: 64
    Achievements:
    7 years registered
    Awards:
    2nd Helpful Member
    betwixt's Avatar
    Join Date
    Jul 2009
    Aberdyfi, West Wales, UK
    Posts
    11,373
    Points
    69,574
    Level
    64
    Don't bother with the EPROM, this is a classic 'stuck key' problem.
    To explain: the keys don't each have their own connection back to the controller, they are grouped together so that four or five of the keys share a common connection. The principle is called multiplexing or 'matrixing' and it makes the keyboard far easier and cheaper to manufacture. Your problem is the '4' key is stuck closed and that is preventing the signal from the other keys in the same group from being recognized.
    Almost certainly as this is a 'gaming' keyboard, the membrane under the '4' key has become permanently stretched so the switch stays closed. Open it up and carefully lift out the three plastic layers of the membrane assembly, there is a top layer, a bottom layer and spacer layer in the middle with holes in it under the key positions. Look carefully and you will see a connection between all the keys that are not working. Normally, when the key is pressed, the top layer (nearest the key cap) is pushed downward through the hole so it touches the bottom layer and makes electrical contact, in your case, the connection isn't breaking when the pressure on the key is released.
    Brian.
    PLEASE - no friends requests or private emails, I simply don't have time to reply to them all.
    It's better to share your questions and answers on Edaboard so we can all benefit from each others experiences.
