How to change rgb led color with a switch (without micro-controller)?
farhang_760
Newbie level 6
Hi
I want to find a way, to controll rgb led color (specific color for example 5 or ten specified color) with a tact switch and without micro-controller. on the other hand want to use simple and cheap material.
thanks for your help
Cheapest solution will be the microcontroller. Simplest will be the logic like counter IC. Just make it count and attach driver to output.
with microcontroller whats your suggestion (low cost)? do you have any sample schematic?
thanks
Assuming that red is the MSB, green the middle bit, and blue is the LSB, any 3 bit binary counter would provide the following sequence:
RGB
000 black
001 blue
010 green
011 cyan
100 red
101 magenta
110 yellow
111 white
repeat....
You could use one half of a 74C393.
The switch would have to be debounced. Google switch debouncing.
