+ Post New Thread
Results 1 to 2 of 2
  1. #1
    Junior Member level 1
    Points: 1,278, Level: 8
    Join Date
    Jan 2011
    Posts
    18
    Points
    1,278
    Level
    8
    Differential Line drivers: Compatibility
    I was hoping to know if the following part numbers are compatible with each other. (one being the transmitter and the other being the receiver).
    1) HS-26CLV31RH (on hardware 1).
    2) HS-26CT32RH (on hardware 2 ).
    Thanks.
    •   Alt9th January 2017, 08:14
      advertising
  2. #2
    Super Moderator
    Points: 239,640, Level: 100
    Awards:
    1st Helpful Member
    Join Date
    Jan 2008
    Bochum, Germany
    Posts
    41,520
    Points
    239,640
    Level
    100
    Re: Differential Line drivers: Compatibility
    Generally speaking, any RS-422 transmitter is compatible with any RS-422 receiver. So are these.
