+ Post New Thread
Results 1 to 14 of 14
  1. #1
    Newbie level 5
    Points: 71, Level: 1
    Join Date
    Nov 2016
    Posts
    9
    Points
    71
    Level
    Integrator for dual slope ADC
    Hello,
    I have designed an integrator with 15 M resistance and 40 PF. The input is a single pulse with a width of 409Us and higher value is 700 mv and lower value is 100mv. The deintegration curve is exponential. How to make it linear?
  2. #2
    Super Moderator
    Points: 239,549, Level: 100
    Awards:
    1st Helpful Member
    Join Date
    Jan 2008
    Bochum, Germany
    Posts
    41,502
    Points
    239,549
    Level
    100
    Re: Integrator for dual slope ADC
    By using a regular dual slope scheme which performs deintegration with Vref, resulting in a linear ramp. See https://en.wikipedia.org/wiki/Integr...C#Basic_design
    •   Alt8th January 2017, 10:07
      advertising
  3. #3
    Advanced Member level 5
    Points: 17,498, Level: 32
    crutschow's Avatar
    Join Date
    Feb 2012
    L.A. USA Zulu -8
    Posts
    3,433
    Points
    17,498
    Level
    32
    To make the discharge curve linear you need a circuit to generate a constant current such as a current mirror.
    Here's
    another article of interest.
    Zapper
    Curmudgeon Elektroniker
    1 members found this post helpful.
  4. #4
    Newbie level 5
    Join Date
    Nov 2016
    Posts
    9
    Points
    71
    Level
    Hello,
    Can you please elaborate a little constant current source should be added where in the circuit?
  5. #5
    Super Moderator
    Awards:
    1st Helpful Member
    Join Date
    Jan 2008
    Bochum, Germany
    Posts
    41,502
    Points
    239,549
    Level
    100
    Where in which circuit? You didn't show your circuit at all.
    The commonly used dual slope ADC circuit (as in the above linked Wikipedia article) is based on an active integrator and won't need a current source, just switches the reference voltage to the integrator.
    •   Alt9th January 2017, 13:21
      advertising
  6. #6
    Newbie level 5
    Join Date
    Nov 2016
    Posts
    9
    Points
    71
    Level
    Quote Originally Posted by FvM View Post
    I used the same circuit as in wikepidea.. My design is integrating but I want to get perfect saw tooth waveform. I have attached the schematic of my circuit.
    •   Alt9th January 2017, 14:55
      advertising
  7. #7
    Super Moderator
    Awards:
    1st Helpful Member
    Join Date
    Jan 2008
    Bochum, Germany
    Posts
    41,502
    Points
    239,549
    Level
    100
    I'm unable to recognize a dual-slope topology in your schematic. It looks more like single slope.
  8. #8
    Newbie level 5
    Join Date
    Nov 2016
    Posts
    9
    Points
    71
    Level
    It is a dual slope topology instead of the control circuit I have given a PWL input. Integration time is 409 Us. I am initially doing the simulation for only one period as I will design the digital part later on.
  9. #9
    Super Moderator
    Awards:
    1st Helpful Member
    Join Date
    Jan 2008
    Bochum, Germany
    Posts
    41,502
    Points
    239,549
    Level
    100
    O.K. we can't see the waveforms. To achieve correct integrator behavior, there should be no resistor R1 permantly connected parallel to the integration capacitor.
  10. #10
    Newbie level 5
    Join Date
    Nov 2016
    Posts
    9
    Points
    71
    Level
    Quote Originally Posted by crutschow View Post
    Here's
    Can you please explain why do we need a constant current circuit and where do we need to conect the constant current source in the op-amp?
  11. #11
    Newbie level 5
    Join Date
    Nov 2016
    Posts
    9
    Points
    71
    Level
    I have tried using the circuit without the resistor, but it does not give proper integration.
  12. #12
    Super Moderator
    Awards:
    1st Helpful Member
    Join Date
    Jan 2008
    Bochum, Germany
    Posts
    41,502
    Points
    239,549
    Level
    100
    You might need a reset switch in place of the resistor.
  13. #13
    Newbie level 5
    Join Date
    Nov 2016
    Posts
    9
    Points
    71
    Level
    Do you mean the switch should be closed at the time of de-integration?
    Quote Originally Posted by pritc View Post
    I have tried using a switch for the deintegration time instead of a resistor parallel to the capacitor. It looks like the circuit is not integrating at all. I have attached the waveform.Click image for larger version.
    •   Alt9th January 2017, 22:51
      advertising
  14. #14
    Super Moderator
    Awards:
    1st Helpful Member
    Join Date
    Jan 2008
    Bochum, Germany
    Posts
    41,502
    Points
    239,549
    Level
    100
    In principle, a dual-slope circuit doesn't need a reset switch if it performs integration and deintegration phase alternatingly. Deintegration would stop when the integrator output voltage is exactly zero.
    Practical dual-slope circuits implement an additional reset or autozero phase after deintegration. In this phase, a reset switch or equivalent reset circuit removes residual integrator charge and provides clean initial conditions for the succeeding integrator phase.
    It seems to me that you are more guessing about dual-slope operation than clearly understanding the principle. You may get more clarity by studying existing dual-slope ADC implementations, e.g. ICs like Intersil ICL7106 or Microchip TC500.
