difference between output conductance and output admittance
julian403
Full Member level 5
Argentina
What the difference between output conductance and output admittance?
Looking the equivalent model
I think rd is output admittance, so where is the output conductance?
rd is a resistor. Impossible to be admittance since admittance is measured in siemens.
Output admittance=Output conductance (just in this case) in your circuit is 1/(rd//RD)
The admittance is the reciprocal of the conductance.
I think is the reciprocal of impedance.
Let see. Conductance is admittance's real part. So I think there is the difference but the admittance (which in the parametter's table is the module) must be bigger than conductance and I do not know why it's not.
In the ac model which one I must use as rd?
So I think there is the difference but the admittance (which in the parameter's table is the module) must be bigger than conductance and I do not know why it's not.
Did you notice the different measurement frequencies? Both specifications can't be compared at all.
The simple model doesn't help because it ignores any reactant circuit elements.
You are right!
Yes, it's just a simple model which I found in internet. I'm using all capacitance in it. The input capacitance which it's between gate and source, outpu capacitance which it's between drain and source and the reverse transfer capacitance which it's between gate and drain.
A realistic RF model will probably have bulk resistance elements in series with Cds and Cdg, resulting in an increasing real admittance component with rising frequency.
Input capacitance is not Cgs, output capacitance is not Cds. Ciss = Cgs+Cgd, Coss=Cds+Cgd
Oh thank! I forgot that, but I can find it with
Cgd=Crrs where Crrs is the reverse transffer capacitance
Cds= Cos - Crrs , where Cos is the output capacitance
Cgs = Ciss - Crrs , where Ciss is the input capacitance.
