+ Post New Thread
Results 1 to 2 of 2
  1. #1
    Member level 2
    Points: 746, Level: 5
    Join Date
    Jan 2015
    Tamil nadu,India
    Posts
    47
    Points
    746
    Level
    How do i know if my simulation of antenna is success
    hi,
    Thanks to edaboard in helping various projects related to antenna engineering
    my doubt is if i finish simulation of patch antenna with what basic parameters like VSWR return loss values i can say i designed correct or good antenna ?and proceed to fabrication of antenna.
    •   Alt7th January 2017, 11:56
      advertising
  2. #2
    Member level 4
    Points: 1,106, Level: 7
    Achievements:
    Created Blog entry
    anilkrpandey's Avatar
    Join Date
    Nov 2016
    Gurgaon
    Posts
    71
    Points
    1,106
    Level
    7
    Blog Entries
    25
    Re: How do i know if my simulation of antenna is success
    If you are getting good return loss and antenna gain in desired frequency band then simulation data should be ok. To cross check, you can simulated same project using different EM technique ( like FEM, FDTD, Methos-of-moment), simulation result should be close with all solvers.
