12V automotive battery capacity tester (STM8).
DeepOne
Advanced Member level 2
45N39E, Russia
this tester will show battery capacity after discharge to preferred minimum voltage value and than disconnect load. end of discharge is marked by sound from buzzer.
  • c_hex_pcb_schm.zip
buttonless version. simple discharge battery to 10,5V.
  • a_tst_kl.rar
Very nice!
I've seen several of your designs, and I'm very impressed with your capability to etch PWBs which will accommodate SMT components.
thanks, but i can not see nothing especial in such design.
Perhaps I should explain a little better what I meant:
It is very easy to make sophisticated and complex designs when one has a lot of money and resources.
It is very difficult when you do the same with limited resources like you do. To do so, it takes a lot of ingenuity and work, and I'm congratulating you on your ingenuity and your work. :thumbsup:
