+ Post New Thread
Results 1 to 8 of 8
  1. #1
    Junior Member level 3
    Points: 372, Level: 4
    Join Date
    May 2016
    Posts
    27
    Points
    372
    Level
    Aluminium PCB trace width
    Hi
    I'm currently working on a BLDC inverter and I need better cooling of SMD MOS-FETs.
    I'm looking into aluminium PCBs and I cant find a guideline or a calculator that shows me how wide the traces must be for a given current.
    PCB will be mounted on a heatsink.
    I need 100A peak for 1-2s and 30A constant current.
    Side question: Has anybody worked with aluminium PCB that then transfers current to a FR4 board? I'm looking into SMD high current jumpers but I can't find any.
    They have to be 20mm in length.
  2. #2
    Advanced Member level 3
    Points: 6,313, Level: 18
    Achievements:
    7 years registered
    Join Date
    Sep 2009
    Lancashire UK.
    Posts
    932
    Points
    6,313
    Level
    18
    Re: Aluminium PCB trace width
    Aluminium as in a aluminium core and copper outer layers\traces?
    or aluminium core and outer traces?
    An interesting question that I look forward to someone being able to answer.
    Before you ask - have you searched the forum? Have you searched Google? - Please do so.
    Please do not ask me in private - ask in public. Also please do not ask me to be a forum friend.
    If I have gone to the effort to help you etc then please have the decency to at least acknowledge it and do not just ask a question then never come back..
  3. #3
    Super Moderator
    Points: 239,577, Level: 100
    Awards:
    1st Helpful Member
    Join Date
    Jan 2008
    Bochum, Germany
    Posts
    41,510
    Points
    239,577
    Level
    100
    I never heard about aluminium PCB traces and can hardly see a purpose of it: no additive galvanic processing, no soldering of regular electronic components possible.
    The term "aluminium PCB" is commonly used for aluminium core.
    O.K. they exist, but apparently for very special applications, with bond interconnect. http://www.omnicircuitboards.com/aluminum-pcb
  4. #4
    Advanced Member level 5
    Points: 13,043, Level: 27
    schmitt trigger's Avatar
    Join Date
    Apr 2013
    C4E4DEEEDCE6ECD2
    Posts
    2,203
    Points
    13,043
    Level
    27
    For many years, there have been alumina ceramic substrates for high power applications. They have good thermal conductivity, electrical insulation and can withstand higher temperatures than FR4.
    And they are usually attached to the heatsink itself.
    Are you sure you are not confusing alumina with aluminum?
    My batteries are recharged by "Helpful Post" ratings.
    If you feel that I've helped you, please indicate it as a Helpful Post
  5. #5
    Join Date
    May 2016
    Posts
    27
    Points
    372
    Level
    I'm thinking about aluminium (or alumina. Not sure as everyone writes aluminium) core PCB.
    Every high power LED application uses this.
    Picture of what I'm thinking about:
    Click image for larger version.
    I found this (page 9 : 4.0 Maximum Copper Foil Current ):
    http://www.bestpcbs.com/design-guide/T-guidePart1.pdf
    Does this seem right to you?
    The numbers seem very high to me.
    Last edited by andre_teprom; 9th January 2017 at 22:02. Reason: upload external picture to post
  6. #6
    Join Date
    Apr 2013
    C4E4DEEEDCE6ECD2
    Posts
    2,203
    Points
    13,043
    Level
    27
    Ok I got you...insulated metal substrate boards.
    In a company which manufactured power supplies, we used to employ these in our higher powered products.
    The current transfer from IMS board to the FR4 main board was achieved with solid copper posts. These posts had been custom stamped and formed from a solid copper wire, and then tin-plated for corrosion protection and solderability. The tin plating may have had an organic layer that protected them from humidity and which would vaporize during reflow solder.
    1 members found this post helpful.
  7. #7
    Join Date
    May 2016
    Posts
    27
    Points
    372
    Level
    I'm probably asking to much but do you happen to have a picture of what this looks like?
    I'm thinking of making something like this but bigger:
  8. #8
    Join Date
    Apr 2013
    C4E4DEEEDCE6ECD2
    Posts
    2,203
    Points
    13,043
    Level
    27
    Sorry, I worked for that company around 2001-2003. But I can describe it to you.
    Our design was two stacked boards (FR4 and IMS), one on top of each other. The lower one was the IMS which was securely attached to a large heat sink.
    The top one was the FR4 where all of the control circuit was installed.
    Connection between the two was for the small signals (gate drive, thermistor sense, etc) via an off-the-shelf header. But the connection for the power signals was made with these custom copper posts.
    As I mentioned earlier these were custom made. A shop purchased solid annealed copper wire, cut them into lengths. Then with a small pneumatic press and a die, one side was stamped flat and that was the side which would sit and solder on the IMS board.
    For final assembly, the two boards were connected together and the post's round side was then hand-soldered to the FR3 board with a large soldering iron.
    Four corner standoffs provided additional mechanical rigidity to the assembly.
