+ Post New Thread
Results 1 to 6 of 6
  1. #1
    Newbie level 3
    Points: 175, Level: 2
    Join Date
    Mar 2016
    Posts
    Points
    175
    Level
    Matlab - RCS calculation surf function
    Hello,
    I am calculating Radar Cross Section with matlab. My results are correct, i want to plot these results.
    I have 2 input variables.
    I use the "surf" function.
    Following RCS values, i want to color the curve. For example, for RCS = -5 to -2, the curve will be yellow, for RCS = 10 to 20, orange, ... I don't know how to do it.
    Can you help me ?
    Click image for larger version.
    •   Alt5th January 2017, 17:03
      advertising
  2. #2
    Points: 6,096, Level: 18
    Join Date
    Dec 2015
    Madrid, Spain
    Posts
    1,092
    Points
    6,096
    Level
    18
    Re: Matlab - RCS calculation surf function
    On the Mathworks page I have found the following:
    surf(Z,C) plots the height of Z, a single-valued function defined over a geometrically rectangular grid, and uses matrix C, assumed to be the same size as Z, to color the surface. See Coloring Mesh and Surface Plots for information on defining C.
    And this is the page where they talk about coloring the surface. Coloring mesh and surface plots
    •   Alt5th January 2017, 17:20
      advertising
  3. #3
    Newbie level 3
    Join Date
    Mar 2016
    Posts
    Points
    175
    Level
    Thank you for your answer.
    I have only values that interest me.
    Now i am trying to color the curve in different part.
    ex : color 1 : values between -5 and -3
    color 2 : values between 3 and 5
    color 3 ...
    I want to keep the surf function for the curve.
    •   Alt6th January 2017, 13:58
      advertising
  4. #4
    Join Date
    Dec 2015
    Madrid, Spain
    Posts
    1,092
    Points
    6,096
    Level
    18
    I do not see the problem.
  5. #5
    Newbie level 3
    Join Date
    Mar 2016
    Posts
    Points
    175
    Level
    I use the surf function to display values. I want to assign colors to the curve in function of range of values. I am not sur if i had to use colormap with conditions.
    •   Alt6th January 2017, 15:11
      advertising
  6. #6
    Join Date
    Dec 2015
    Madrid, Spain
    Posts
    1,092
    Points
    6,096
    Level
    18
    You can assign the "C" matrix the values you want.
    This is a MATLAB script assigning red,green and blue.
    clear
    clc
    A=ones(25,25);%create a simple matrix with the dimension required (mXn)
    %Here, start changing the matrix C1 as you wish
    C1 = zeros(size(A));  % filling First RGB table
    for row=1:12
        for column=1:12
            C1(row,column)=1;
        end
    end
    for row=13:17
        for column=13:17
            C1(row,column)=0;
        end
    end
    for row=18:25
        for column=18:25
            C1(row,column)=0;
        end
    end
    C2 = zeros(size(A));    % filling Second RGB table
    for row=1:12
        for column=1:12
            C2(row,column)=0;
        end
    end
    for row=13:17
        for column=13:17
            C2(row,column)=1;
        end
    end
    for row=18:25
        for column=18:25
            C2(row,column)=0;
        end
    end
    C3 = zeros(size(A));    % filling Third RGB table
    for row=1:12
        for column=1:12
            C3(row,column)=0;
        end
    end
    for row=13:17
        for column=13:17
            C3(row,column)=0;
        end
    end
    for row=18:25
        for column=18:25
            C3(row,column)=1;
        end
    end
    %Define the 3 RGB tables with C1,C2,C3
    C(:,:,1)=C1;
    C(:,:,2)=C2;
    C(:,:,3)=C3;
    Z = peaks(25);
    surf(Z,C)
    title('EXAMPLE')
    And here is its plot. You can do better, but you got my point.
    You have to assign in each RGB table the value you want.
    I have made this:
    • rows 0 to 12 and columns 0 to 12 --> asign RED which means in table one is 1, in table 2 is 0 and in table 3 is 0
    • rows 13 to 17 and columns 13 to 17 --> asign GREEN which means in table one is 0, in table 2 is 1 and in table 3 is 0
    • rows 18 to 25 and columns 18 to 25 --> asign BLUE which means in table one is 0, in table 2 is 0 and in table 3 is 1
    So it would be like this:
    Color<--->Table 1<--->Table 2<--->Table 3
    RED<--->1<--->0<--->0
    GREEN<--->0<--->1<--->0
    BLUE<--->0<--->0<--->1
