+ Post New Thread
Results 1 to 3 of 3
  1. #1
    Full Member level 2
    Points: 1,469, Level: 8
    arunbharathi.arasu's Avatar
    Join Date
    Feb 2013
    Chennai, Tamil Nadu, India
    Posts
    132
    Points
    1,469
    Level
    8
    GSM Message Read Problem
    Dear all,
    I facing problem while read message.
    when i read msg some letters are missing.
    +CMGR:"REC UNREAD","+918754449444","",""17/08/17,15:48:23"
    Hi, this is message
    The above is the message format and message what i get from GSM.
    shows in Terminal.
    but when i read this i got
    +CMGR:"REC UNREAD","+918754449444","",""17/08/17,154823"
    Hthi is mssg
    Like this. letters are missing form time..
    body of the message also missing.
    I have checked by sending the data what i received.
    Learn from Yesterday...............
    Live for Today.........
    Hope for tomorrow.............
    •   Alt3rd January 2017, 11:27
      advertising
  2. #2
    Member level 1
    Points: 787, Level: 6
    Join Date
    Jan 2014
    Bangalore, India
    Posts
    36
    Points
    787
    Level
    Re: GSM Message Read Problem
    Hello Arun,
    I understand that the GSM module works as expected. But it is on the microcontroller side that you are missing some characters.
    1. Assuming you are using a microcontroller, what microcontroller are you using?
    2. How are you handling UART receive? via. interrupt or by polling?
    3. How do you handle the received characters? That is, can you explain how you receive the characters and buffer it to your array?
    Regards,
    Raj Gunaseelan James
    •   Alt4th January 2017, 09:04
      advertising
  3. #3
    Full Member level 2
    Join Date
    Feb 2013
    Posts
    132
    Points
    1,469
    Level
    8
    Dear Raj Gunaseelan ,
    problem solved. thanks.
    hi,
    Now i can read first message properly.
    But i cannot read second message.
    main program inside while
    while(1)    {
        if(msgflag==1)
         MSG_READ();
         count=0;
        delay(1000);
        msgflag=0;
    My interrupt code is
    unsigned char *ok="OK",*error="ERROR",*newmsg="+CMTI: "SM",1";
    void interrupt uart_ISR()
        if(RCIF==1)
           Rx_data=RCREG;
           RCIF=0;
           if(Rx_data!= 0x0A)
             Arraydata[count]= Rx_data;
             count++;
           else
            Arraydata[count]=0;
            if(flag);
            else
            count=0;
           arrayptr=Arraydata;
           if(flag)
               data=Arraydata;
           if(strstr(arrayptr,ok))
               RC_BIT_Flag=1;
           else if(strstr(arrayptr,error))
               RC_BIT_Flag=0;
           else if(strstr(arrayptr,newmsg))
              msgflag=1;
    please let me if any error..
    I can read ok,error,and first message but if i am reading secound message i cannot.
    once i read message i will delete the message
    void MSG_READ()
        flag=1;
        trans_string("AT+CMGR=1\r");
        delay(500);
        flag=0;
        trans_string("AT+CMGD=1\r");
        delay(100);
    here i used flag. because after message i received "ok".
    so im using flag to stop "count=0" in interrupt.
    Thanks in advance..
