+ Post New Thread
Results 1 to 6 of 6
  1. #1
    Newbie level 6
    Points: 253, Level: 3
    Join Date
    Nov 2016
    Posts
    13
    Points
    253
    Level
    Ads momentum simulation
    Good afternoon!
    I have elaborated topology for my LNA antenna amplifier, and after that i tried simulate my amplifier with topology in schemanic. And DC results for biasing transistors too much differ from those without topologie. What can cause difference?
    Could you also give me a link for use Ads Momentum and EM simulation?
    I have removed all breaks in topology. Now i guess it can be in VIA elements(that is holes for connecting to ground)
    The vias is cond layer(as the top layer), is it wrong? Layer for ground is cond2.
    •   Alt2nd January 2017, 19:25
      advertising
  2. #2
    Advanced Member level 5
    Points: 25,939, Level: 39
    Join Date
    Nov 2001
    Earth
    Posts
    3,666
    Points
    25,939
    Level
    39
    Re: Ads momentum simulation
    Have you started your simulation from 0 Hz ??
    •   Alt2nd January 2017, 20:10
      advertising
  3. #3
    Newbie level 6
    Join Date
    Nov 2016
    Posts
    13
    Points
    253
    Level
    Yes, the frequency plan from 0Hz to 5GHz.
    •   Alt2nd January 2017, 20:56
      advertising
  4. #4
    Join Date
    Nov 2001
    Earth
    Posts
    3,666
    Points
    25,939
    Level
    39
    Quote Originally Posted by Dragon65 View Post
    For DC, RF Mode should be chosen.Even-tough there are still problems ( possible ) connect DC paths using with Ideal RF Choke but RF mode and well organized Ports and Meshing should work at DC.
  5. #5
    Newbie level 6
    Join Date
    Nov 2016
    Posts
    13
    Points
    253
    Level
    Should I incorporate this ideal RF chokes in schematic and create topology with them?
    •   Alt11th January 2017, 20:36
      advertising
  6. #6
    Member level 4
    Points: 1,106, Level: 7
    Achievements:
    Created Blog entry
    anilkrpandey's Avatar
    Join Date
    Nov 2016
    Gurgaon
    Posts
    71
    Points
    1,106
    Level
    7
    Blog Entries
    25
    Below are two references
    1. Momentum Basics : http://cp.literature.agilent.com/lit...um_Basics.html
    2. ADS Cookbook : http://cp.literature.agilent.com/lit...991-1516EN.pdf
