+ Post New Thread
Results 1 to 4 of 4
  1. #1
    Newbie level 3
    Points: 205, Level: 2
    Join Date
    Sep 2016
    Posts
    Points
    205
    Level
    Question about electronic terms (SMII/SS-SMII, TX, RX)
    Hi
    Following sentences are some parts of a datasheet, please take a look at them and tell the difference between the marked terms.
    • In SMII/SS-SMII, TXD1 is not used and should be tied either high or low.
    • In SMII/SS-SMII, RXD1is not used and they are driven low.
    • RMII mode;no switch controller is connected; and TX_EN[7:0] is pulled down.
    • 'Pd' stand for internal pull down (75K ohm)
    Thanks in advance.
    •   Alt1st January 2017, 06:50
      advertising
  2. #2
    Member level 5
    Points: 651, Level: 5
    Join Date
    Aug 2016
    Bangalore, India
    Posts
    80
    Points
    651
    Level
    Re: Question about electronic terms (SMII/SS-SMII, TX, RX)
    Quote Originally Posted by HOSSEINGHODS View Post
    Hi
    Thanks in advance.
    Tied high means connected to Vcc using some current limiting resistor.
    Tied low/driven low/pulled down/internal pull down means connected to gnd again using current limiting resistor.
    •   Alt1st January 2017, 15:57
      advertising
  3. #3
    Newbie level 3
    Join Date
    Sep 2016
    Posts
    Points
    205
    Level
    Thanks, some other questions;
    1. consider a pin which is internally pulled up (with an internal 75 K ohm resistor), is it necessary to pull this pin up externally? I have seen people doing this!
    2. what does keep logic low level mean?
    •   Alt2nd January 2017, 08:15
      advertising
  4. #4
    Member level 5
    Join Date
    Aug 2016
    Bangalore, India
    Posts
    80
    Points
    651
    Level
    1. I think adding an external pull up resistor will leads to a strong pull up for that particular pin.
    2. "keep logic low" --> connecting the specific pin to logic '0' voltage or pulled down.
    1 members found this post helpful.
