+ Post New Thread
Results 1 to 5 of 5
  1. #1
    Newbie level 6
    Points: 221, Level: 2
    Join Date
    Aug 2016
    Posts
    13
    Points
    221
    Level
    Find material for ferrite core
    Hi!
    I want to make some ferrite core for microwave experiment, where can I find epoxy or silicone rubber for ferrite core?
    •   Alt29th December 2016, 17:43
      advertising
  2. #2
    Super Moderator
    Points: 46,764, Level: 52
    Join Date
    Apr 2011
    Minneapolis, Minnesota, USA
    Posts
    11,656
    Points
    46,764
    Level
    52
    Re: Find material for ferrite core
    From a web article I got the idea to cut up steel wool into tiny slivers, and mix it into a slurry with silicone caulk/ sealant/ adhesive. Available in hardware and automotive stores.
    I tried it with short lengths of soda straw. The slurry was about a 50-50 mix. I made a messy job of tamping it into the straw. I wound about a hundred turns of thin wire. The result is 100 or 200 uH.
    •   Alt29th December 2016, 18:40
      advertising
  3. #3
    Super Moderator
    Points: 239,549, Level: 100
    Awards:
    1st Helpful Member
    Join Date
    Jan 2008
    Bochum, Germany
    Posts
    41,502
    Points
    239,549
    Level
    100
    Ferrites are ferromagnetic oxydes, ferrite cores are sintered like ceramics. In so far I don't see where epoxy or silicone resin comes into play.
    •   Alt29th December 2016, 19:01
      advertising
  4. #4
    Advanced Member level 5
    Points: 13,005, Level: 27
    Join Date
    May 2015
    Melbourne, Australia
    Posts
    2,213
    Points
    13,005
    Level
    27
    You can buy ferrite in just about an shape, size or configuration imaginable.
    I cannot imagine why you would want to make your own.
    Cheers, Tony.
  5. #5
    Newbie level 6
    Join Date
    Aug 2016
    Posts
    13
    Points
    221
    Level
    If I want to use epoxy, are there difference for production of ferrite core and Hypermarkets?
