+ Post New Thread
Results 1 to 4 of 4
  1. #1
    Full Member level 1
    Points: 880, Level: 6
    Join Date
    Feb 2016
    Posts
    116
    Points
    880
    Level
    s parameters for small length wires
    how to get (simulate) s parameters of small length wires (ic output is connected to sma through pictel connection) in ads. i want to know the impact of the wire on the s parameter of the design. is the length of the wire will impact the overall parameters.
    in case of transmission line we can use a lambda/2 line(of same characteristic impedance) and connect to any port without changing it's parameter. just like the transmission line is there any particular length of wire for which the parameters will not be effected by the wire.
    •   Alt22nd December 2016, 11:21
      advertising
  2. #2
    Super Moderator
    Points: 239,566, Level: 100
    Awards:
    1st Helpful Member
    Join Date
    Jan 2008
    Bochum, Germany
    Posts
    41,505
    Points
    239,566
    Level
    100
    Re: s parameters for small length wires
    A wire isn't a complete circuit, you can't determine its s parameters without specifying the return path, e.g. distance to a ground plane.
    Multiple wires implement a mutual coupling and need to be described by a n-dimensional s-parameter matrix.
    •   Alt22nd December 2016, 17:55
      advertising
  3. #3
    Full Member level 1
    Join Date
    Feb 2016
    Posts
    116
    Points
    880
    Level
    sorry for the improper term, by wire i meant the cable connected between the sma connector and the board. instead of using the rf cable i have used a smaller length cable, i wanted to know whether a small length of that can cause unwanted effect. i am working in the 3-10 GHz range so for this range also the wavelength is also 3cm. my cable is ~1cm
    •   Alt27th December 2016, 12:42
      advertising
  4. #4
    Advanced Member level 2
    Points: 5,735, Level: 17
    Join Date
    Mar 2002
    Posts
    509
    Points
    5,735
    Level
    17
    As a crude method to simulate you can use a stripline element, make Er =1.0, the Thickness &width = the diameter of the wire, L = 1cm , and the substraight
    height will be your closest ground reference distance.
    But at 3-10GHz expect orders of magnitude variation between simulation and implimentation.
    Good luck.
