+ Post New Thread
Results 1 to 2 of 2
  1. #1
    Full Member level 5
    Points: 3,538, Level: 13
    leomecma's Avatar
    Join Date
    Jun 2005
    Brasil
    Posts
    242
    Points
    3,538
    Level
    13
    HFSS antenna imput impedance
    I need simulate an antenna in HFSS for RFID. The internal impedance of IC at 915MHz is 12.8-j248 (NXP UCODE7). This is a serie impedance.
    To simulate this impedance I use a Lumped port with equivalent parallel resistance Rp ~ 4.837K and a capacitance of 0.7pF in parallel using a lumped RLC. Both in parallel connected to a dipole input.
    Antenna needs be 12.8+j248 impedance for perfect match.
    My question:
    When I measure Z11 in HFSS, the real and imaginary part showed is parallel or serie modeled?
    My doubt is because real part depends of the configuration.
    •   Alt21st December 2016, 12:15
      advertising
  2. #2
    Advanced Member level 3
    Points: 6,008, Level: 18
    Join Date
    Jun 2012
    Edmonton, Canada
    Posts
    944
    Points
    6,008
    Level
    18
    Re: HFSS antenna imput impedance
    If there's only one port, then Z11 is the input impedance of your entire network, as seen from that port.
