+ Post New Thread
Results 1 to 3 of 3
  1. #1
    Full Member level 1
    Points: 3,002, Level: 12
    zainka's Avatar
    Join Date
    Nov 2004
    No(r)way
    Posts
    111
    Points
    3,002
    Level
    12
    gauge vs open-ended differential pressure sensors
    Hi
    Working on a pressurized device using gauge sensors. Not much experience there, but generally spoken, is it correct that an gauge sensor rated for 1psi do the same as an 2psi differential pressure sensor where one end is left open/unconnected in free atmosphere?
    Please apologize if I am all wrong on this...
    Breg
    Vidar
    •   Alt18th December 2016, 22:47
      advertising
  2. #2
    Advanced Member level 5
    Points: 13,005, Level: 27
    Join Date
    May 2015
    Melbourne, Australia
    Posts
    2,213
    Points
    13,005
    Level
    27
    Re: gauge vs open-ended differential pressure sensors
    A gauge sensor and differential sensor are exactly the same.
    Only difference is the gauge sensor has only one external connection, the atmospheric port is inside and not accessible.
    A differential sensor has two external ports, but you can just leave one open to atmosphere and use the other as a gauge port.
    Both will read pressure above (or below) atmospheric, and they will read the same.
    Cheers, Tony.
    •   Alt18th December 2016, 23:21
      advertising
  3. #3
    Full Member level 1
    zainka's Avatar
    Join Date
    Nov 2004
    No(r)way
    Posts
    111
    Points
    3,002
    Level
    12
    Quote Originally Posted by Warpspeed View Post
    Very good then, so I was correct on something finally. Thats a nice christmas gift to know...... Thanks for the confirmation.
    It gives a wider range of sensors to purchase as replacement and that was what I wanted to have confirmed.
