+ Post New Thread
Results 1 to 9 of 9
  1. #1
    Points: 649, Level: 5
    Join Date
    Sep 2013
    Posts
    Points
    649
    Level
    SIM808 Sleep Mode Enable and Disable Programmatically
    Hello All,
    Im trying to put the sim808 module into the sleep mode for a period of time, and want wake it up after a certain time. But im not able to put the device in the sleep mode.
    I have used AT+CSCLK=1 command in my code to make it happen. but on using this my code is not compiling, im getting compilation error.
    I got stuck at this point, please help me out in this.
    Thanks
  2. #2
    Points: 7,100, Level: 20
    Achievements:
    7 years registered Created Blog entry
    dpaul's Avatar
    Join Date
    Jan 2008
    Germay
    Posts
    1,032
    Points
    7,100
    Level
    20
    Blog Entries
    Re: SIM808 Sleep Mode Enable and Disable Programmatically
    Probably you have posted this in the wrong sub-forum.
    Try the "Digital communication" sub-forum.
    I never new what sim808 is until I put it to google.
    .....yes, I do this for fun!
    •   Alt12th December 2016, 09:46
      advertising
  3. #3
    Join Date
    Sep 2013
    Posts
    Points
    649
    Level
    Hello All,
    Thanks
  4. #4
    Super Moderator
    Points: 239,577, Level: 100
    Awards:
    1st Helpful Member
    Join Date
    Jan 2008
    Bochum, Germany
    Posts
    41,508
    Points
    239,577
    Level
    100
    Thread moved.
    but on using this my code is not compiling, I'm getting compilation error.
    Problem doesn't seem to be related to SIM908. Show the code and error message.
    •   Alt12th December 2016, 11:35
      advertising
  5. #5
    Join Date
    Sep 2013
    Posts
    Points
    649
    Level
    Hello Sir,
    im using the SIMCOM808 module in project.
  6. #6
    Join Date
    Sep 2013
    Posts
    Points
    649
    Level
    Need help with SIMCOM808 Module
    Hello ALL Group Members,
    I am new to this forum, and i mistakenly post my query in more than 1 forum/group.
    I dont have any idea for posting the related query to the relevant group.
    Is there any one who can tell me where i should post my query on the relevant forum/group so that i can go further with my work.
    I have posted many times, but no reply i get from any one.
    Please help me.
    Thanks
  7. #7
    Super Moderator
    Awards:
    1st Helpful Member
    Join Date
    Jan 2008
    Bochum, Germany
    Posts
    41,508
    Points
    239,577
    Level
    100
    Allow me to quote a forum rule first:
    Thread bumping is not allowed
    Don't bump your thread with useless followups like “please help” or “no one” etc. and don’t be in a hurry to get a reply, be patient. If you have any additional info to provide (like results gathered after the posted question or additional info) then you are welcome to post them in order to explain better your problem.
    Your thread has been finally moved to microcontrollers section after it revealed as a coding problem. You are just right here.
    You got already answers and you can expect more specific help if you start to give meaningful information.
    Up to now you have only reported a compilation error without posting any code and error messages.
  8. #8
    Join Date
    Sep 2013
    Posts
    Points
    649
    Level
    Hello FvM,
    Thanks for your reply.
    Now coming to point.
    When im not using this command AT+CSCLK=1 in a called function, im not getting any compilation error. but when i used this command which is called using a user defined function, so my code is not compiling. Im receiving the compilation error.
    Thanks
    •   Alt12th December 2016, 13:39
      advertising
  9. #9
    Super Moderator
    Awards:
    1st Helpful Member
    Join Date
    Jan 2008
    Bochum, Germany
    Posts
    41,508
    Points
    239,577
    Level
    100
