+ Post New Thread
Results 1 to 6 of 6
  1. #1
    Full Member level 5
    Points: 2,244, Level: 10
    Join Date
    Jan 2012
    Posts
    280
    Points
    2,244
    Level
    10
    What tool do I need for these connectors?
    Take a look at the image attached. I've used a simple plier to crimp the wire to the end-piece (or what you call them), but the result is never good. What type of tool do I need to make reliable connections with these kind of connectors? Or perhaps someone could recommend other types of connectors to be used? I'm just looking for a cheap, simple and reliable way to make connectors that can be connected to pcb's, as an alternative to soldering the wires directly to the board. I'm also not sure what the English names for these connectors and tools are:(
    •   Alt7th December 2016, 09:29
      advertising
  2. #2
    Super Moderator
    Points: 57,531, Level: 58
    Achievements:
    7 years registered
    Awards:
    Most Frequent Poster 3rd Helpful Member
    Join Date
    Apr 2014
    Posts
    11,710
    Points
    57,531
    Level
    58
    Re: What tool do I need for these connectors?
    please find out which manufacturer and which crimp connector type this is.
    At the manufacturer homepage you will find approriate tools.
    You want it cheap? Often theese tools are far away from beeing cheap.
    But why:
    Those tools need to be producece especially for those crimp connectors... with very tight mechanical tolerance.
    The steel needs to be hardened not to wear out soon.
    A crimp connection is one of the most reliable connection types, but only if it is made correctely.
    It needs a huge ammount of pressure so that the connection between wire and crimp contact is like welded. You can not open a correctely made crimp connection.
    Both wire and crimp contact are "one" piece of metal. Only if this is the case, then you have optimal crimp quality.
    There are many cheap tools on the market.
    * many of the have too low force to make the connection like welded.
    * some of them have not the correct geometry and the press at a plce of the crimp contakt that hurts mechanical stability and the contact may break easily.
    * some of them are not of good quality, not hardened. Maybe the produce good quality at first, but then they soon wear out and the crimp quality decreases. But this is not obvious and you may find out with failures in the field. Not good.
    Klaus
    •   Alt7th December 2016, 10:00
      advertising
  3. #3
    Full Member level 4
    Points: 2,566, Level: 11
    Achievements:
    7 years registered
    Join Date
    Feb 2009
    Kolkata
    Posts
    193
    Points
    2,566
    Level
    11
    I have bought one crimping tool that suits to this connector pin (CPU conector). Also there is provision to crimp Relimate connector too. This tool is of Ashwin make (Model - HT004). See the image. This is not a cheap tool. I had to part with INR2500. But quality of the product is superb.
    •   Alt7th December 2016, 12:04
      advertising
  4. #4
    Full Member level 5
    Join Date
    Jan 2012
    Posts
    280
    Points
    2,244
    Level
    10
    Sorry for not getting back to this thread. I think I'm going to have to buy a proper tool even at high expense. What are these connectors called exaclty? I'm not sure where to look :( I found the Ashwin HT004, but I couldn't find a price for it, do I have to request a price directly from Ashwin? The site that sells me these connectors is just a cheap site in Asia that give no information about what tool I need, I can send them an email though.
  5. #5
    Super Moderator
    Points: 241,412, Level: 100
    Awards:
    1st Helpful Member
    Join Date
    Jan 2008
    Bochum, Germany
    Posts
    41,904
    Points
    241,412
    Level
    100
    The connectors look like replica of major manufacturers (e.g. Molex) types. Contacts may be identical to or different from the original, don't know.
    Expect a price of the original hand crimping tool in a 200 - 300 $ range. There are nevertheless cheap (about $20) tools from the Far East that might fit your connector series like the type below
    •   Alt26th May 2017, 08:16
      advertising
  6. #6
    Super Moderator
    Points: 28,611, Level: 41
    ads-ee's Avatar
    Join Date
    Sep 2013
    USA
    Posts
    6,550
    Points
    28,611
    Level
    41
    Quote Originally Posted by FvM
    They don't seem to be quite that expensive...
    http://www.newark.com/molex/63811-10...2in/dp/85C2464
    This is from the guys who invented that Molex connector...on the same page there appears to be the exact same crimp connector in your picture.
