Disable Reset while installing driver USB Serial COM
Ahmad Edi Saputra
Junior Member level 2
Dear All
i need help with these 2 case
1. Can I disable modem reset (DTR pulse) while installing driver usb to serial port? so when i plug usb to serial, pin DTR will always remain low (or high), default instaling usb serial while generate about 3 or 4 pulse on pin DTR.
2. Can I detect usb event plugged/unlpug with java? if not, what programming language should i use?
Dear All
I have never attempted to access a USB device in Java but it should be possible
have a look at
http://usb4java.org/index.html
in C++ if you are connecting to a USB HID device you could use the HID API
for example, this loops until the device is plugged in
	// Open the device using the VID, PID,
	while(!(handle = hid_open(0x4d8, 0x3f, NULL)))
		printf("unable to open device\n");
 		Sleep(2000);
	cout << "USB HID device connected VID & PID OK" << endl;
a run gives
if using C++, C#, VB.NET etc have a look at
http://msdn.microsoft.com/en-us/library/windows/hardware/ff540174(v=vs.85).aspx
http://msdn.microsoft.com/en-us/windows/hardware/drivers/hid/finding-and-opening-a-hid-collection
Java for HID devices
https://github.com/nyholku/purejavahidapi
it is very easy to use - a run of
import java.util.List;
import purejavahidapi.*;
public class Example1 {
	public static void main(String[] args) {
	    System.out.println("start search for HID devices");
		try {
			List<HidDeviceInfo> devList = PureJavaHidApi.enumerateDevices();
			for (HidDeviceInfo info : devList) {
				System.out.printf("VID = 0x%04X PID = 0x%04X Manufacturer = %s \n", //
						info.getVendorId(), //
						info.getProductId(), //
						info.getManufacturerString());//
		} catch (Exception e) {
			e.printStackTrace();
gives
C:\temp\jtemp>java -cp .;purejavahidapi.jar;jna-4.0.0.jar Example1
VID = 0x04F3 PID = 0x0103 Manufacturer = null
VID = 0x04D8 PID = 0xF4DB Manufacturer = Microchip Technology Inc.
C:\temp\jtemp>
there is also
https://github.com/gary-rowe/hid4java
