+ Post New Thread
Results 1 to 5 of 5
  1. #1
    Member level 1
    Points: 1,809, Level: 9
    Join Date
    Jul 2004
    Solar System
    Posts
    32
    Points
    1,809
    Level
    9
    idss fet
    Hello,
    What is the meaning of Idss (Zero-Gate Voltage Drain Current) of a FET. Is it the smaller the value, the better the FET?
    Also what is Vgs, the smaller the better?
    Thanks & best regards.
    •   Alt11th April 2005, 04:33
      advertising
  2. #2
    Advanced Member level 5
    Points: 74,061, Level: 66
    Join Date
    Oct 2004
    West Coast
    Posts
    7,942
    Points
    74,061
    Level
    66
    fet parameters
    Idss ia a current when Vgs=0V.
    Value is just different for different FETs and do not descibe the transistors quality ..
    With Vgs you probably mean Vgsoff which is a Vgs voltage at which Id=0 (or near to). Again, different value for diffrent transistor with no preferences ..
    1 members found this post helpful.
    •   Alt11th April 2005, 04:45
      advertising
  3. #3
    Member level 1
    Join Date
    Jul 2004
    Solar System
    Posts
    32
    Points
    1,809
    Level
    9
    fet idss
    Thanks! Ian.
    Still I didn't get much from what you said. For example Idss (as you mentioned when Vgs=0V). In this case, the FET is off, right? Then an ideal FET should have Idss=0?
    •   Alt11th April 2005, 05:10
      advertising
  4. #4
    Join Date
    Oct 2004
    West Coast
    Posts
    7,942
    Points
    74,061
    Level
    66
    idss in fet
    At Vgs=0 FETs conduct certain current: for example the popular BF245C has Idss=12mA, but BF245A has only Idss=2mA.
    As I mentioned befor FET is off at Vgsoff what can be for N-FET somewhere below -5V and varies fro differen FETs.
  5. #5
    Points: 12,011, Level: 26
    Join Date
    Mar 2005
    USA
    Posts
    1,326
    Points
    12,011
    Level
    26
    fet parameterts
    saturn,
    A depletion mode junction FET is ON with Vgs = 0. Under this condition, the drain current is relatively independent of the Drain-Source voltage.
    This is the Idss.
    Idss is not a measure of quality. It is a measure of the maximum current that you can expect the FET to support.
    Vgs, or Vgsoff is the magnitude of Gate-to-Source voltage that is required to turn the FET OFF. It is given for a maximum Drain current, e.g., 200uA, and a specified Drain-to-Source voltage, e.g., 10V. For an N-channel depletion mode junction FET, Vgsoff is negative; for a P-channel FET, it is positive. Vgs is not a measure of quality.
    For a given family of FETs, the higher the Vgsoff is, the higher will be the Idss.
    For a given family of FETs, the higher the Idss value, the lower will be the rdson (drain-to source resistance). The rdson parameter is usually only specified for FETS that are intended for switching applications.
    Regards,
    Kral
    2 members found this post helpful.
