Base drift removal of ecg
SINGHAVANI
Newbie level 1
Code vb.net - [expand]
8
9
10
11
12
13
14
15
16
17
18
clear;
system('rdsamp -r e0801 -f 17.3 -l 10.0 -p > e0801.txt');  % jump 17.3 seconds, read 10 seconds
[t,y(:,1),y(:,2)] = textread('e0801.txt','%f %f %f');      % read time and voltages from file
fs = 1 / (t(2) - t(1));                 % sample rate, hertz
period = 0.96;                          % cardiac period, seconds
N = length(y);
t = (0 : N-1) / fs;
for n = 1:2                             % for each voltage waveform
  subplot(4,1,n*2-1); plot(t,y(:,n)); xlim([0 max(t)]);
  title('Input Data','FontWeight','bold'); xlabel('Seconds'); ylabel('Millivolts');
  xlim1 = xlim;  ylim1 = ylim;          % remember plot limits
  % Subtract baseline drift. See [url]https://www.dataq.com/applicat/articles/an14.htm[/url]
  z(:,n) = y(:,n) - smooth(y(:,n),round(fs*period));
  subplot(4,1,n*2-0); plot(t,z(:,n)); xlim([0 max(t)]);
  title('Subtract Baseline Drift','FontWeight','bold'); xlabel('Seconds'); ylabel('Millivolts');
  xlim(xlim1);
end;
for above code getting this error
init: can't open header for record e0801
Attempted to access t(2); index out of bounds because numel(t)=0.
Error in ecgdat (line 4)
plz help
Why don't you debug the line which precedes the error on line #4, such as plotting the content of the variable 't' to check if the text was realy read from file, and also to see if its content was correctly allocated on the matrix ? In addition, if the above was wrote in MATLAB, shouldn't the calculation on line #7 have been made with the dot division matrix operator (./) ?
