[Merged]: Measuring Reverse Leakage Current
poachedpig
Newbie level 5
Somewhere over the rainbow
I have this circuit, it's actually a differential rectifier.
How do I measure the reverse leakage current of my PMOS if my input is in AC?
Is it possible to measure the leakage current directly on my circuit? Or do I have to characterize the MOS and use a testbench to measure the leakage?
I did tried measuring the current through the node drain, it seems a bit large. So I am in doubt.
Reverse Leakage Current of a Rectifier
I am trying to study the operation of this circuit,
I am trying to measure the REVERSE LEAKAGE CURRENT of my main mos, but I don't really have any idea how.
A friend of mine told me to use this testbench,
The only problem is that her circuit is of DC in nature and mine is a passive rectifier which is AC. Also, my MOS function as a diode. I am not sure if it is applicable to my situation.
I tried to measure the current through the drain node of my PMOS directly to my circuit. But it seems like it is pretty large for a leakage current. I assumed it was wrong.
Do I have to isolate my main mos and auxiliary mos to measure the reverse leakage current?
Re: Reverse Leakage Current of a Rectifier
It is not wrong.
That is a true result of your circuit.
No.
Auxiliary PMOS is no more than bias circuitry to feed bias voltage fo gate of main PMOS.
It is not wrong.
No.
If I understand it correctly, the subthreshold leakage current is the current flowing from source to drain. So I assumed that I can measure the leakage current from the current flowing from the drain.
I wanted to measure the leakage current in a single cycle where the mos is in off state, with respect to time.
Just like in the plot above. Am I still gonna use Transient analysis for this? (sorry, I am not familiar with the rest of the tools)
