+ Post New Thread
Results 1 to 11 of 11
  1. #1
    Full Member level 4
    Points: 3,762, Level: 14
    Join Date
    Nov 2004
    Posts
    220
    Points
    3,762
    Level
    14
    Units of Time Constant are Seconds... But Why?
    It is a known fact that time constant of a series circuit is RC that is ohm*farad... But how come the units are seconds? Similarly we also have T=L/R Henry/Ohm...even then the units are seconds... Can someone tell me how the units are arrived at? Please help....
  2. #2
    Junior Member level 2
    Points: 1,504, Level: 8
    Join Date
    Apr 2005
    Posts
    23
    Points
    1,504
    Level
    8
    Re: Unists of Time Constant are Seconds... But Why?
    let's look at the equations and the units:
    C=Q/V
    [Farad]=[colomb/volt]
    R=V/I
    [ohm]=[volt/amper]
    I=dQ/dt
    [amper]=[colomb/time]
    RC=(V/I)*(Q/V) --> [RC]=[volt/amper]*[colomb/volt]
    [RC]=[volt*time/colomb]*[colomb/volt]=[time]
    •   Alt10th April 2005, 15:05
      advertising
  3. #3
    Member level 3
    Points: 1,773, Level: 9
    Join Date
    Jan 2005
    Panama
    Posts
    56
    Points
    1,773
    Level
    9
    Re: Units of Time Constant are Seconds... But Why?
    And, in a simple way, let's see the other one:
    T= L/R
    in a coil: V=L(di/dt) or we can just say: V=L(I/t), resulting in: L= [(V)(t)] / I
    Ohm's Law: I=V/R then: R= V/I
    In the end: L/R = [(V)(t) / I] / (V/I)
    ..( L ) .. ( V*t ) .. ( I )
    ..----- = ------- * ------ = t (seconds)
    ..( R ) ... ( I ) .... ( V )
    See ya! 8)
    •   Alt11th April 2005, 09:03
      advertising
  4. #4
    Member level 4
    Points: 2,359, Level: 11
    AndrzejM's Avatar
    Join Date
    Dec 2004
    Szczecin-Poland
    Posts
    71
    Points
    2,359
    Level
    11
    In ancient times (100 years ago) all electrical units were express on the primary units basis:
    (centimetre, gram, second) OR (meter,kg, second).
    For example the electrical capacity unit was "cm" ,
    the resistance unit was "sec" .
    The electrical charge unit was (cm ^3/2 gram ^1/2 sec^-1 )
    (Isn't it strange? )
    Units for current, voltage and other were in form of the multiplication/division (and their fractional powers) of c,g,s primary units.
    Time constant was "sec x cm" !
    The text was completly rewritten 12-04-2005.
    (Without checking I assumed, that unit for time constant would be "sec" in SI and cgs systems, closer analyse gives conclusions described above).
    •   Alt11th April 2005, 10:21
      advertising
  5. #5
    Points: 15,991, Level: 30
    Join Date
    Mar 2002
    Posts
    1,309
    Points
    15,991
    Level
    30
    Quote Originally Posted by purifier
    All things are calculated in SI units, and if you check a website about SI units, you can find how all units are derived. There are 7 SI base unites and all other SI units are derived from these and can be expressed in terms of SI base units
    Check this site for example: http://physics.nist.gov/cuu/Units/units.html
    The 7 SI base units:
    Base quantity               	Name    	Symbol
    length  	                    meter  	 m
    mass 	                       kilogram   kg
    time 	                       second     s
    electric current 	           ampere 	 A
    thermodynamic temperature      kelvin 	 K
    amount of substance 	        mole 	   mol
    luminous intensity 	         candela 	cd
    Expression in terms of SI base units:
    Electrical resitance, R (ohm) [Ω]: m^2 kg s^-3 A^-2
    Capacitance, C (farad) [F]: m^-2 kg^-1 s^4 A^2
    Inductance, L (henry) [H]: m^2 kg s^-2 A^-2
    If you multiply the two SI units for R and C, you will end up with the SI unit seconds:
    RC: (m^2 kg s^-3 A^-2) (m^-2 kg^-1 s^4 A^2) = s
    If you devide the SI unit for L with the SI unit for R, you will also end up with the SI unit seconds:
    L/R: (m^2 kg s^-2 A^-2) / (m^2 kg s^-3 A^-2) = s
    Whenever you are in doubt which unit you will end up with when you multiply, divide, add or subtract more units, just check the SI units and you will know which unit you will end up with.
  6. #6
    Advanced Member level 5
    Points: 74,061, Level: 66
    Join Date
    Oct 2004
    West Coast
    Posts
    7,942
    Points
    74,061
    Level
    66
    Without using matematical equasions, just try to imagine this:
    Charge/discharge a capacitor .. How much time you need to discharge/charge it?
    The answer is time, and it will be reflected in s, ms, s so on ..
  7. #7
    Full Member level 1
    Points: 4,277, Level: 15
    lokeyh's Avatar
    Join Date
    Sep 2004
    Posts
    106
    Points
    4,277
    Level
    15
    The time required to charge a capacitor to 63 percent (actually 63.2 percent) of full charge or to discharge it to 37 percent (actually 36.8 percent) of its initial voltage is known as the TIME CONSTANT (TC) of the circuit. Hence the unit for time constant is seconds.
  8. #8
    Newbie level 1
    Points: 1,383, Level: 8
    Join Date
    Apr 2005
    Posts
    Points
    1,383
    Level
    8
    [R]=[V]/[I]
    [C]=[Q]/[V]=[I]*[t]/[v]
    so [R*C]=[R]*[C]=[t]
    •   Alt11th April 2005, 12:04
      advertising
  9. #9
    Full Member level 6
    Points: 3,633, Level: 14
    Join Date
    Jun 2004
    Sao Paulo - Brasil
    Posts
    332
    Points
    3,633
    Level
    14
    Simplifying all messages above:
    1 farad = 1 coulomb / 1 volt
    1 coulomb = 1 ampere * 1 second
    so 1 farad = 1 ampere * 1 second / 1 volt
    1 ohm = 1 volt / 1 ampere
    multiplying 1 farad and 1 ohm, we have
    (1 ampere * 1 second / 1 volt) * (1 volt / 1 ampere)
    volts and amperes are cancelled
    and
    that remains 1 second (only time unit)
  10. #10
    Full Member level 4
    Join Date
    Nov 2004
    Posts
    220
    Points
    3,762
    Level
    14
    Thanks a lot... I never expected that many replies... I guess this time i'll think a little before posting such questions... I wonder why i got such a doubt :)
  11. #11
    Points: 1,474, Level: 8
    Join Date
    Mar 2005
    Posts
    22
    Points
    1,474
    Level
    8
    the proportions are constant
