vhdl multiplier 4 bit by 4 bit design with shift registers and adder
HARD_VHDL
Newbie level 1
How can I code this multipler?
4 * 4 signed multiplier with shift register and adder.
Would I get some examples?
Please help me.
There are many ways to do it:
An easy to understand method:
* To find out sign of result: XOR both input sign bits
* then make both inputs positive ( ==> only 3 bits unsigned)
* multiply both values: 3 bits x 3 bits = 6 bits result
* If the result is negative (output of XOR) then invert the multiplication result
* form a 7 bit signed integer
Just the 3 x 3multiplication:
Let's say ABC are the three bits of the first multiplicator
And XYZ of the second multiplicator:
ABC x XYZ =
C x 00XYZ
B x 0XYZ0
A x XYZ00
=  RRRRRR
Klaus
