+ Post New Thread
Results 1 to 3 of 3
  1. #1
    Points: 1,164, Level: 7
    Join Date
    Sep 2010
    Posts
    Points
    1,164
    Level
    7
    How to construct a ring oscillator using inverters (NOT gates) in simulink ?
    I would like to see how the phases of each inverter stage in the ring changes with time. If i connect odd number of inverter stages and probe the last stage with a scope, I am getting this error "Cannot solve algebraic loop involving 'untitled/Logical Operator' because it consists of blocks that cannot be assigned algebraic variables, such as blocks with discrete-valued outputs, blocks with non-double or complex outputs, Stateflow blocks, or nonvirtual subsystems. Consider breaking the algebraic loop. For example, add a delay or a memory block to the loop."
    •   Alt17th November 2016, 10:05
      advertising
  2. #2
    Super Moderator
    Points: 25,606, Level: 38
    andre_teprom's Avatar
    Join Date
    Nov 2006
    Brazil
    Posts
    7,699
    Points
    25,606
    Level
    38
    Blog Entries
    Re: How to construct a ring oscillator using inverters (NOT gates) in simulink ?
    I would recommend you attach a snapshot of the diagram that you're trying to simulate, as well to post the exact error message reported.
    Part of the world that you live in, You are the part that you're giving ( Renaissance )
    •   Alt17th November 2016, 15:44
      advertising
  3. #3
    Super Moderator
    Points: 239,611, Level: 100
    Awards:
    1st Helpful Member
    Join Date
    Jan 2008
    Bochum, Germany
    Posts
    41,515
    Points
    239,611
    Level
    100
    According to the error message you are trying to build a ring oscillator with delay-less inverters. That's not possible.
