+ Post New Thread
Results 1 to 7 of 7
  1. #1
    Newbie level 6
    Points: 110, Level: 1
    Join Date
    Sep 2016
    Posts
    12
    Points
    110
    Level
    power required of broadcast transmission
    Hi all,
    I want to know the power required by node i to broadcast its data to 2 nodes is it the sum of power ofrequired for each node separetly ??
    •   Alt14th November 2016, 15:38
      advertising
  2. #2
    Advanced Member level 1
    Points: 2,896, Level: 12
    Join Date
    Jan 2011
    Posts
    410
    Points
    2,896
    Level
    12
    Re: power required of broadcast transmission
    No. If the antenna is omnidirectional, then ideally the power per unit area at a given distance in any direction is the same.
    •   Alt19th November 2016, 21:13
      advertising
  3. #3
    Newbie level 6
    Join Date
    Sep 2016
    Posts
    12
    Points
    110
    Level
    Quote Originally Posted by David83 View Post
    thanks for the response,
    the nodes are distante from the source by d1 and d2 .Since the power is function of the distance how the power is the same ??
    •   Alt19th November 2016, 22:27
      advertising
  4. #4
    Super Moderator
    Points: 70,402, Level: 64
    Achievements:
    7 years registered
    Awards:
    2nd Helpful Member
    betwixt's Avatar
    Join Date
    Jul 2009
    Aberdyfi, West Wales, UK
    Posts
    11,521
    Points
    70,402
    Level
    64
    What David83 is saying is an omnidirectional source produces a spherical radiation pattern. The strength decreases as the distance increases but the signal is there at all locations at all times. How much of it you receive is a proportional to the distance the to receiver location but one receiver does not influence what another picks up.
    Brian.
    PLEASE - no friends requests or private emails, I simply don't have time to reply to them all.
    It's better to share your questions and answers on Edaboard so we can all benefit from each others experiences.
    1 members found this post helpful.
  5. #5
    Advanced Member level 5
    Points: 13,519, Level: 27
    Join Date
    Nov 2012
    Posts
    2,519
    Points
    13,519
    Level
    27
    What David83 is saying is an omnidirectional source produces a spherical radiation pattern. The strength decreases as the distance increases but the signal is there at all locations at all times. How much of it you receive is a proportional to the distance the to receiver location but one receiver does not influence what another picks up..
    If the emission pattern is spherically symmetric, the signal strength decreases as the inverse square of the distance. In other words, the signal strength (W/m2) will be 1/4 at twice the distance.
    If the emission is confined to a circular plane, the signal strength decreases as the inverse of the distance: the signal will be half as weak at twice the distance.
    If the emission is confined to a parallel beam (pencil), the signal strength is independent of the distance.
    Of course these are idealizations and are far from reality. You will mostly find that the signal always decreases as the inverse square of the distance (even if the beam has been focussed, it still has some divergence). That is where the directional pattern of the particular antenna comes in the picture.
  6. #6
    Join Date
    Jan 2011
    Posts
    410
    Points
    2,896
    Level
    12
    Quote Originally Posted by hmayna View Post
    I said (ideally) the power at any given distance in any direction is the same. What power a node receives doesn't affect the power the other node receives. A node receives a power that's proportional to its distance from the transmitter. It doesn't matter how many nodes there are as receivers.
    •   Alt20th November 2016, 18:28
      advertising
  7. #7
    Newbie level 6
    Join Date
    Sep 2016
    Posts
    12
    Points
    110
    Level
    But I talk about the transmit power of node i to node j which is proportional to the distance of transmission. In the equation (1) of this paper http://people.rennes.inria.fr/Olivie...2007/NBS07.pdf is the transmit power of the source to a destination D which distant d ,when we have a destination D1 distant d1 from the source, the transmit power is simply we remplace d by d1 .But when the source broadcast to D and D1 what is the transmit power ??
