+ Post New Thread
Results 1 to 10 of 10
  1. #1
    Full Member level 3
    Points: 2,428, Level: 11
    Achievements:
    7 years registered
    Join Date
    Nov 2009
    Pakistan
    Posts
    183
    Points
    2,428
    Level
    11
    Problem changing PCI Parallel Port address to 0x378
    Hello I am using a PCI based parallel card to program my FPGA as provided by the manufacturer. The software readme.txt says to change the parrallel port address to 0x378 to run the burn software.
    I am using Dell Optiplex 9010 with A13.0 Version of BIOS. I am unable to find the change of Address settings in my BIOS. can anyone help me with this issue. Thanks
    •   Alt7th November 2016, 06:53
      advertising
  2. #2
    Advanced Member level 5
    Points: 11,741, Level: 25
    Achievements:
    7 years registered
    Join Date
    Apr 2010
    Posts
    1,800
    Points
    11,741
    Level
    25
    Re: Problem changing PCI Parallel Port address to 0x378
    the pci card will assign the address to 378 if it is programmed. Are you trying to set up the BIOS before testing the card?
    Did you boot the system with the pci card and see the operation ?
  3. #3
    Full Member level 3
    Achievements:
    7 years registered
    Join Date
    Nov 2009
    Pakistan
    Posts
    183
    Points
    2,428
    Level
    11
    yes i did restart the pc, and yes i installed the drivers for PCI card but it didnt set its address to 378. I want to change its address to 378 through BIOS or any other way
  4. #4
    Achievements:
    7 years registered
    Join Date
    Apr 2010
    Posts
    1,800
    Points
    11,741
    Level
    25
    does your system has a parallel port in the motherboard ?
    Do you see LPT in BIOS?
    •   Alt7th November 2016, 07:13
      advertising
  5. #5
    Full Member level 3
    Achievements:
    7 years registered
    Join Date
    Nov 2009
    Pakistan
    Posts
    183
    Points
    2,428
    Level
    11
    I dont have Parallael port on my motherboard, thats why i am using PCI based Parallel card, and BIOS just shows that a parallel card is inserted on PCI slot number 3. No option for editing
  6. #6
    Achievements:
    7 years registered
    Join Date
    Apr 2010
    Posts
    1,800
    Points
    11,741
    Level
    25
    Then your PCI card will work at the said address.
    You will not have the option in BIOS.
  7. #7
    Super Moderator
    Points: 55,114, Level: 57
    Achievements:
    7 years registered
    Awards:
    Most Frequent Poster 3rd Helpful Member
    Join Date
    Apr 2014
    Posts
    11,148
    Points
    55,114
    Level
    57
    Sometimes you can configure this with the OS.
    Klaus
  8. #8
    Full Member level 3
    Achievements:
    7 years registered
    Join Date
    Nov 2009
    Pakistan
    Posts
    183
    Points
    2,428
    Level
    11
    Quote Originally Posted by KlausST View Post
    Klaus
    can you please tell me a way through which i can change it through OS settings
  9. #9
    Super Moderator
    Achievements:
    7 years registered
    Awards:
    Join Date
    Apr 2014
    Posts
    11,148
    Points
    55,114
    Level
    57
    I'm not sure if I can, but surely not before you say what OS you use.
    Klaus
    •   Alt7th November 2016, 20:35
      advertising
  10. #10
    Super Moderator
    Points: 25,606, Level: 38
    andre_teprom's Avatar
    Join Date
    Nov 2006
    Brazil
    Posts
    7,699
    Points
    25,606
    Level
    38
    Blog Entries
    Quote Originally Posted by fouwad View Post
    You did not mention so far what is that PCI based parallel card; brand, specifications, etc...
    Part of the world that you live in, You are the part that you're giving ( Renaissance )
