+ Post New Thread
Results 1 to 4 of 4
  1. #1
    Full Member level 1
    Points: 1,101, Level: 7
    Join Date
    Jul 2014
    Posts
    96
    Points
    1,101
    Level
    7
    can i use wifi module alone to control system
    hello
    i have arduino and wifi module esp8266 on tx side , i want to control relay using only wi fi at rx side.
    is it possible to do that??
    if not then how could i do that??
    thanks
    •   Alt24th October 2016, 05:55
      advertising
  2. #2
    Newbie level 2
    Points: 336, Level: 3
    Join Date
    Feb 2016
    Posts
    Points
    336
    Level
    Re: can i use wifi module alone to control system
    You can clearly do what you want. In fact you dont need an arduino or any mcu.
    ESP8266 is an programmable Wifi module. You can upload your sketch with Arduino IDE or LUA.
    You can switch your relay by the help of a tansistor.
    1 members found this post helpful.
    •   Alt24th October 2016, 10:21
      advertising
  3. #3
    Full Member level 1
    Join Date
    Jul 2014
    Posts
    96
    Points
    1,101
    Level
    7
    so, it mean i have to upload my Arduino sketch to wifi module using Arduino ide. am i going right??
    •   Alt27th December 2016, 06:03
      advertising
  4. #4
    Newbie level 2
    Join Date
    Feb 2016
    Posts
    Points
    336
    Level
    Yes you're right.
    You need :
    1) USB to UART Converter(Must be 3.3v). This can be FT232RL or CP2102 Modules.
    2) https://github.com/esp8266/Arduino
    In this site you can see how you will upload your sketch to your ESP8266 Module.
