+ Post New Thread
Results 1 to 2 of 2
  1. #1
    Member level 1
    Points: 647, Level: 5
    Join Date
    Aug 2015
    Posts
    37
    Points
    647
    Level
    Vintage IBM thinkpad 380XD , processor upgrade issue
    I was planning on upgrading my old laptop , from a pentium mmx to a pentium II, I have even bought the pentium II processor for it, But this is a weird issue for this Laptop, and i have no idea why IBM would do this, this laptop could come with a pentium mmx or a pentium II , this is where the issue, is IBM had a different BIOS for each processor , There was a different bios for the pentium mmx and than a different bios for the pentium II version, So based on the processor you want, they install a different bios, I have looked at the motherboards of a pentium mmx and pentium II model , they are identical to each other, the only different is what i have said above. If anyone on here has had this laptop model, have you ever tried to update the pentium mmx model to the pentium II model by changing the bios? Should i even attempt to change the bios on this laptop? I really want to update this laptop to the pentium II , So what should i do?
    •   Alt2nd October 2016, 23:38
      advertising
  2. #2
    Member level 1
    Join Date
    Aug 2015
    Posts
    37
    Points
    647
    Level
    Re: Vintage IBM thinkpad 380XD , processor upgrade issue
    Update not going to work, I found out i would need another voltage regular board, since the pentium MMX and the pentium II processors are a different voltage
