+ Post New Thread
Results 1 to 6 of 6
  1. #1
    Member level 3
    Points: 999, Level: 7
    Join Date
    Mar 2014
    Posts
    62
    Points
    999
    Level
    7
    Arabic Language LED MATRIX Dot matrix display using ARDUINO or PIC or AT89S51
    Hi Programmers.
    i want to make Arabic Language led matrix display .
    And i have no idea where to start .
    I have made English Led matrix display.
    Click image for larger version.
    •   Alt29th September 2016, 14:27
      advertising
  2. #2
    Super Moderator
    Points: 26,005, Level: 39
    andre_teprom's Avatar
    Join Date
    Nov 2006
    Brazil
    Posts
    7,841
    Points
    26,005
    Level
    39
    Blog Entries
    Re: Arabic Language LED MATRIX Dot matrix display using ARDUINO or PIC or AT89S51
    With no code, no chance to get effective help.
    Anyway, as a general advice, the obvious recommendation is to change the character map.
    Part of the world that you live in, You are the part that you're giving ( Renaissance )
    •   Alt29th September 2016, 14:41
      advertising
  3. #3
    Super Moderator
    Points: 241,412, Level: 100
    Awards:
    1st Helpful Member
    Join Date
    Jan 2008
    Bochum, Germany
    Posts
    41,906
    Points
    241,412
    Level
    100
    Guess you'll start with defining a character generator matrix and determine how many rows and columns are required, variable character width?
    •   Alt29th September 2016, 14:44
      advertising
  4. #4
    Member level 3
    Join Date
    Mar 2014
    Posts
    62
    Points
    999
    Level
    7
    Do you mean "save all sentence in memory map " and just scroll it?
  5. #5
    Super Moderator
    Join Date
    Nov 2006
    Brazil
    Posts
    7,841
    Points
    26,005
    Level
    39
    Blog Entries
    Quote Originally Posted by easy electronics View Post
    Not the sencence, but the alphabet bitmap. The standard strategy is to program the code in different functional layers: In short, one to define the character (in general, in static memory), other to scan each character, and another to scan the whole phrase.
    Anyway, if you have already done that, I was expecting you show your code to ask what should have to do.
    •   Alt29th September 2016, 15:53
      advertising
  6. #6
    Points: 8,284, Level: 21
    Easyrider83's Avatar
    Join Date
    Oct 2011
    Tallinn, Estonia
    Posts
    1,486
    Points
    8,284
    Level
    21
    May be the problem itself is that arabic letters consist of different symbols means something. In this case it is impossible to save single character for each letter. So, there are two ways how to solve it - build some sort of character contructiong engine wich will combine symbols to letters or simple store the whole word as a sprite and reproduce it on screen at needed position. Anyway, I don't see any problems to stop me to solve this task both ways. May be autor just need more practice first?
    Love me or hate me. All infractions will be ignored.
