+ Post New Thread
Results 1 to 4 of 4
  1. #1
    Junior Member level 3
    Points: 697, Level: 5
    Join Date
    Aug 2013
    Posts
    31
    Points
    697
    Level
    TDA7294 problem low sound
    hi
    i build an amplifire with tda7294 and connect input of amp to output of y laptop and connect output of amplifire to a 4ohm/50watt speaker and put the volume of my laptop at max and the speaker sound like a 5watt speaker and after 60 second tda7294 with a huge cpu heatsink beacome very very very hot and output sound was about 5 watt
    the power supply was +-33 volts and there wasnt any addotional circuit and build amplifire with datasheet circuit.input signal was at high level
    so please help me where is the problem????
    •   Alt23rd September 2016, 18:48
      advertising
  2. #2
    Advanced Member level 5
    Points: 48,446, Level: 53
    Achievements:
    7 years registered
    Audioguru's Avatar
    Join Date
    Jan 2008
    Toronto area of Canada
    Posts
    8,423
    Points
    48,446
    Level
    53
    Re: TDA7294 problem low sound
    Did you use the recommended pcb design shown in the datasheet? If you made a different pcb design then the amplifier might be oscillating at a high frequency which will cause it to get very hot.
    •   Alt23rd September 2016, 20:23
      advertising
  3. #3
    Super Moderator
    Points: 54,878, Level: 57
    Achievements:
    7 years registered
    Awards:
    Most Frequent Poster 3rd Helpful Member
    Join Date
    Apr 2014
    Posts
    11,115
    Points
    54,878
    Level
    57
    Show your exact circuit. All known voltages, signals and connections.
    Maybe an additional picture.
    Klaus
      advertising
  4. #4
    Points: 25,337, Level: 38
    Join Date
    Dec 2010
    Southampton and holiday cottage in Wensleydale (UK)
    Posts
    4,863
    Points
    25,337
    Level
    38
    Choice of two problems:- 1 there is a wiring fault, 2 bad layout or decoupling causing high frequency oscillations. So if you have a scope put it on the output see if you can see any wave form with no input. If its oscillating then the wave form is normally huge like+- Vcc p-p. in this case the layout and or decoupling is wrong. Often touching a sensitive part of the circuit will change the frequency or stop it, use a screwdriver. If your wiring is rubbish you might have wired it up wrong and used positive feedback instead of negative. If you have no scope build a high frequency detector, .1Mf, one end as input other side going to a diode to earth, junction of diode going of to your DVM on DCV via a 10K other side of DVM going to earth. Polarity depends on which the diodes connected. To test probe use the input signal, should get a reading.
    Measure the Vcc, disconnect the amp, Vcc should not change by more then a few volts.
    I am dubious about your heat sink, a big one is 250mm X 250mm X 75 mm, CPU heat sinks tend to be a lot smaller (100mm square) but fan cooled.
    Frank
