+ Post New Thread
Results 1 to 3 of 3
  1. #1
    Junior Member level 2
    Points: 343, Level: 3
    Join Date
    Sep 2016
    Posts
    23
    Points
    343
    Level
    Desoldering and soldering IC with power pad
    Hi
    I am looking for a rework station for soldering and desoldering of IC with power pad. That is IC with metal landing at the bottom for soldering onto the plane of the pcb for better heat conduction.
    Thanks
    Alan
    •   Alt21st September 2016, 08:38
      advertising
  2. #2
    Super Moderator
    Points: 25,540, Level: 38
    andre_teprom's Avatar
    Join Date
    Nov 2006
    Brazil
    Posts
    7,686
    Points
    25,540
    Level
    38
    Blog Entries
    Re: Desoldering and soldering IC with power pad
    Never did that before, but perhaps you should consider the same nozzle set used for desoldering BGA components, although most of them are sold for use with both SMD/BGA packages.
    Part of the world that you live in, You are the part that you're giving ( Renaissance )
    •   Alt21st September 2016, 17:00
      advertising
  3. #3
    Advanced Member level 5
    Points: 34,929, Level: 45
    Join Date
    Mar 2008
    USA
    Posts
    5,587
    Points
    34,929
    Level
    45
    The Nice Ladies In The Lab used a small heat gun and
    gravity. Although a temperature-tolerant vacuum wand
    or gently applied tweezers might be easier than working
    upside down.
