Calculation of Gain and Bandwidth for Differential Amplifier
niteshtripathi
Member level 3
Hello everyone,
I have to design a fully differential amplifier design. I have been given the following specs, How to calculate the gain and bandwidth of the amplifier:
The given specs are:
1)Close Loop Gain
2)Max Input Step
3)Max Gain Error
4)Max Settling error
5)Max Settling Time
6)PSR
some other parameter like vdd,load cap,input/output commom mode range etc. are also given. Any Suggestion please?
Is this homework?
You gave no values, no circuit, no opamp type....so I assume you want general answers.
Like 1) closed loop gain = V_out / V_in
There is no difference between single ended or differential amplifier
Please clarify what you really want..
Klaus
Is this homework?
Klaus
Actually these parameters are given for a fully differential amplifier. How to relate these parameters with gain and bandwidth. Any Suggestions?
