+ Post New Thread
Results 1 to 5 of 5
  1. #1
    Newbie level 3
    Points: 25, Level: 1
    Join Date
    Aug 2016
    Posts
    Points
    25
    Level
    vhdl code simulation
    hi ,i wrote a vhdl code for a common bus(8 bit) that have four registers and simple alu that do some simple logical and arithmetic operation.r0,r1 and r3 inputs are connected to bus and r2 input is connected to alu output.r1 and r2 output like r0 and r3 are connected to bus via muxs and too(r1,r2)
    are connected to alu inputs.then consequently i wrote the testbench but i dont know why the registers input and output why dont initialized and have undefined values.please help me.
    Code VHDL - [expand]
    8
    9
    10
    11
    12
    13
    14
    15
    16
    17
    18
    19
    20
    21
    22
    23
    24
    25
    26
    27
    28
    29
    30
    31
    32
    33
    34
    35
    36
    37
    38
    39
    40
    41
    42
    43
    44
    45
    46
    47
    48
    49
    50
    51
    52
    53
    54
    55
    56
    57
    58
    59
    60
    61
    62
    63
    64
    65
    66
    67
    68
    69
    70
    71
    72
    73
    74
    75
    76
    77
    78
    79
    80
    81
    82
    83
    84
    85
    86
    87
    88
    89
    90
    91
    92
    93
    94
    95
    96
    97
    98
    99
    100
    101
    102
    103
    104
    105
    106
    107
    108
    109
    110
    111
    112
    113
    114
    115
    116
    117
    118
    119
    120
    121
    122
    123
    124
    125
    126
    127
    128
    129
    130
    131
    132
    133
    134
    135
    136
    137
    138
    139
    140
    141
    142
    143
    144
    145
    146
    147
    148
    149
    150
    151
    152
    153
    154
    155
    156
    157
    158
    159
    160
    161
    162
    163
    164
    165
    166
    167
    168
    169
    170
    171
    172
    173
    174
    175
    176
    177
    178
    179
    180
    181
    182
    183
    184
    185
    186
    187
    188
    189
    190
    191
    192
    193
    library ieee;
    use ieee.std_logic_1164.all;
    use ieee.std_logic_unsigned.all;
    use ieee.std_logic_arith.all;
    -- instead off two past sentenses you are authorized for using use ieee.numeric_std.all;
    entity comm_bus is
        port(r0_in,r1_in,r3_in:inout std_logic_vector(0 to 7);
             --r2_in is not needed because we use from alu_out
             r0_out,r1_out,r2_out,r3_out:inout std_logic_vector(0 to 7);
             -- registers input & output must be identified inout and you dont have any way
             r0_clr,r1_clr,r2_clr,r3_clr:in std_logic;
             clk:in std_logic;
             r0_ld,r1_ld,r2_ld,r3_ld:in std_logic;
             opr:in std_logic_vector(2 downto 0);
             sel:in std_logic_vector(1 downto 0);
             bus_8bit:inout std_logic_vector(0 to 7));
    end comm_bus;
    -- for alu operation & selection mechanism we wana use from interface signals-----------
    architecture behavioral of comm_bus is
    signal alu_arm1,alu_arm2,alu_out:std_logic_vector(0 to 7);
    --signal opr:std_logic_vector(2 downto 0);
    --signal sel:std_logic_vector(1 downto 0);
    begin
        process(clk)
            begin
                if (rising_edge(clk)) then
                   if (r0_clr='0') then
                       r0_out<=(others=>'0');
                   end if;
                   if (r1_clr='0') then
                       r1_out<=(others=>'0');
                   end if;
                   if (r2_clr='0') then
                       r2_out<=(others=>'0');
                   end if;
                   if (r3_clr='0') then
                       r3_out<=(others=>'0');
                   end if;
                 end if;
         end process;
         process(clk)
             begin
                    if (r0_ld='1') then
                        r0_out<=r0_in;
                    end if;
                    if (r1_ld='1') then
                        r1_out<=r1_in;
                    end if;
                    if (r2_ld='1') then
                        r2_out<=alu_out;
                       --alu_out directly transfer to r2_out
                    end if;
                    if (r3_ld='1') then
                        r3_out<=r3_in;
                    end if;
                end if;
          end process;
          r0_in<=bus_8bit;
          r1_in<=bus_8bit;
          r3_in<=bus_8bit;
          -- please attention r2 register input directly is connected to alu output
          process(sel)
              begin
                  case sel is
                      when "00" =>
                          bus_8bit<=r0_out;
                      when "01" =>
                          bus_8bit<=r1_out;
                      when "10" =>
                          bus_8bit<=r2_out;
                      when "11" =>
                          bus_8bit<=r3_out;
                      when others => null;
                   end case;
               end process;
               alu_arm1<=r1_out;
               alu_arm2<=r2_out;
               with opr select
                  alu_out<=alu_arm1 + alu_arm2 when "000",
                           alu_arm1 - alu_arm2 when "001",
                           alu_arm1 and alu_arm2 when "010",
                           alu_arm1 or alu_arm2 when "011",
                           alu_arm1 nand alu_arm2 when "100",
                           alu_arm1 xor alu_arm2 when "101",
                           not alu_arm1 when "110",
                           not alu_arm2 when "111",
                           "--------" when others;
        end behavioral;
    library ieee;
    entity top_module_comm_bus is
    end top_module_comm_bus;
    architecture testbench of top_module_comm_bus is
    constant t:time:=20 ns;
    constant d:integer:=4;
    constant dd:integer:=200;
    signal r0_in,r1_in,r3_in:std_logic_vector(0 to 7);
    signal r0_out,r1_out,r2_out,r3_out:std_logic_vector(0 to 7);
    signal bus_8bit:std_logic_vector(0 to 7);
    signal r0_clr,r1_clr,r2_clr,r3_clr:std_logic;
    signal r0_ld,r1_ld,r2_ld,r3_ld:std_logic;
    signal clk:std_logic;
    begin
        uut: entity work.comm_bus(behavioral) port map(r0_in=>r0_in,r1_in=>r1_in,
         r3_in=>r3_in,r0_out=>r0_out,r1_out=>r1_out,r2_out=>r2_out,r3_out=>r3_out,
         r0_clr=>r0_clr,r1_clr=>r1_clr,r2_clr=>r2_clr,r3_clr=>r3_clr,
         r0_ld=>r0_ld,r1_ld=>r1_ld,r2_ld=>r2_ld,r3_ld=>r3_ld,clk=>clk,
         bus_8bit=>bus_8bit,
         opr=>opr,
         sel=>sel);
    -- 20 ns clock is running forever
    process
    begin
        clk<='0';
        wait for t/2;
        clk<='1';
        wait for t/2;
    end process;
    --clear all of registers and then released them
    --process
    --begin
        --r0_clr<='0';
        --r1_clr<='0';
        --r2_clr<='0';
        --r3_clr<='0';
        --r0_ld<='0';
        --r1_ld<='0';
        --r2_ld<='0';
        --r3_ld<='0';
        --wait for d*t;
        --r0_clr<='1';
        --r1_clr<='1';
        --r2_clr<='1';
        --r3_clr<='1';
        --wait;
    --end process;
    r0_clr<='0','1' after t;
    r1_clr<='0','1' after t;
    r2_clr<='0','1' after t;
    r3_clr<='0','1' after t;
    r0_ld<='1','0' after t;
    r1_ld<='1','0' after t;
    r2_ld<='1','0' after t;
    r3_ld<='1','0' after t;
    -- now for example we have two numbers one of them in r1 and another one in r2
    -- at first we add them and put result in r0 and again do some logical operation
    -- on two registers r1 and r2 and this time put the result in r3
    process
    begin
        wait for d*d*t;
        bus_8bit<="10011100";
        wait for t;
        r1_ld<='1';
        wait for t;
        r1_ld<='0';
        opr<="000";
        wait for t;
        r2_ld<='1';
        wait for t;
        r2_ld<='0';
        wait for t;
        sel<="10";
        wait for t;
        sel<="--";
        r0_ld<='1';
        wait for t;
        r0_ld<='0';
        wait for t;
        opr<="010";
        wait for t;
        r2_ld<='1';
        wait for t;
        r2_ld<='0';
        wait for t;
        sel<="10";
        wait for t;
        sel<="--";
        wait for t;
        r3_ld<='1';
        wait for t;
        r3_ld<='0';
        wait for dd*d*t;
    end process;
    end testbench;
    •   Alt12th August 2016, 06:24
      advertising
  2. #2
    Super Moderator
    Points: 241,468, Level: 100
    Awards:
    1st Helpful Member
    Join Date
    Jan 2008
    Bochum, Germany
    Posts
    41,921
    Points
    241,468
    Level
    100
    Re: vhdl code simulation
    You apparently want to feed data though bus_8bit to the comm_bus unit. But an inout port must be tristated to receive data. You never do.
    There are probably more elementary design faults. But this one is already sufficient to make the design fail.
    •   Alt12th August 2016, 08:11
      advertising
  3. #3
    Newbie level 3
    Join Date
    Aug 2016
    Posts
    Points
    25
    Level
    hi ,thank .may be give more information about your mean how i must make inout tristate?
    •   Alt12th August 2016, 08:29
      advertising
  4. #4
    Super Moderator
    Awards:
    1st Helpful Member
    Join Date
    Jan 2008
    Bochum, Germany
    Posts
    41,921
    Points
    241,468
    Level
    100
    You should sketch a schematic of the logic you are going to design. A bidirectional signal like bus_8bit must be driven by a tri-state buffer. It can be only read when the buffer is disabled. In VHDL syntax, tri-stating is done by writing 'Z' to the port.
  5. #5
    Newbie level 3
    Join Date
    Aug 2016
    Posts
    Points
    25
    Level
    Quote Originally Posted by FvM View Post
    hi
    very thanks ,i find my response from your answer.
