+ Post New Thread
Results 1 to 3 of 3
  1. #1
    Newbie level 5
    Points: 94, Level: 1
    Join Date
    Jul 2016
    Posts
    9
    Points
    94
    Level
    [Moved]: Microstrip patch antenna design in HFSS or CST using LTCC material
    Hy every one. I am new in LTCC. I have designed Patch antenna in HFSS before using Rogers substrate 1.5mm thick. Now I want to design it with LTCC material. But I don't know how to choose LTCC substrate and how to design such antenna in HFSS . Anyone please help me. A step by step procedure will be helpful for me. Thank you
    •   Alt30th July 2016, 15:58
      advertising
  2. #2
    Full Member level 5
    Points: 3,186, Level: 13
    Achievements:
    7 years registered Created Blog entry
    Join Date
    Jul 2007
    Trieste
    Posts
    285
    Points
    3,186
    Level
    13
    Blog Entries
    Re: [Moved]: Microstrip patch antenna design in HFSS or CST using LTCC material
    It is better that you follow YouTube Tutorials of HFSS they are very elaborate and most of time step by step guide to execute the task
    •   Alt31st July 2016, 11:32
      advertising
  3. #3
    Full Member level 6
    Points: 2,303, Level: 11
    Join Date
    Aug 2015
    Coral Springs, Florida
    Posts
    327
    Points
    2,303
    Level
    11
    Why do you need a step-by-step proceedure? You have already done one in HFSS, but just using a different material.
    Don't know the LTCC material to use? Ask your vendor for specs on the FIRED materials that he uses. Select the one that meets your criteria.
    When designing with LTCC, just remember to design with PRE-FIRED dimensions, but simulate with POST-FIRED dimensions. (Or develop the patch you want, then add the LTCC shrinkage factor to the design for your vendor.)
    1 members found this post helpful.
