+ Post New Thread
Results 1 to 5 of 5
  1. #1
    Junior Member level 2
    Points: 1,004, Level: 7
    Join Date
    May 2012
    Posts
    20
    Points
    1,004
    Level
    7
    1HP motor for stewart platform
    I am planning to use 6 1HP motors for stewart platform for a payload mass of 800kgs. I am curious to know what is the difference between the Lenze/Varvel motors and 1HP motors used as for pumping water as there is a 10x difference in price. Can I use 1HP water pump motor for my application?
    SIGNATURE ADVERTISING IS NOT ALLOWED
    •   Alt14th July 2016, 23:01
      advertising
  2. #2
    Advanced Member level 5
    Points: 34,278, Level: 45
    Achievements:
    7 years registered Created Blog entry Created Album pictures
    SunnySkyguy's Avatar
    Join Date
    Sep 2007
    Richmond Hill, ON, Canada
    Posts
    6,633
    Points
    34,278
    Level
    45
    Blog Entries
    7
    Re: 1HP motor for stewart platform
    where are the datasheets?
    A good design question lists your overall requirements™ The best question deserves a better answer. ™
    ... Tony Stewart EE since 1975
    •   Alt15th July 2016, 00:13
      advertising
  3. #3
    Super Moderator
    Points: 46,819, Level: 52
    Join Date
    Apr 2011
    Minneapolis, Minnesota, USA
    Posts
    11,670
    Points
    46,819
    Level
    52
    These might be factors to consider:
    * How does the motor act with no load? Most motors run faster. Will this cause the light end of your platform to rise more quickly than the heavy end of the platform?
    * How does the motor act when stalled by an unmovable load? How much current does it draw? Can motor survive? Can this happen with your platform?
    * What amount of surge current does the motor draw at startup? Could either type of motor create a problem in this area?
    * If the above factors create a problem, then can either type of motor be regulated to fix the problem?
    •   Alt15th July 2016, 02:49
      advertising
  4. #4
    Points: 13,328, Level: 27
    Join Date
    Nov 2012
    Posts
    2,484
    Points
    13,328
    Level
    27
    The output of the 6 motors must be sync'ed; I guess they are driving the same load at different ends.
    You need to analyze what happens if one fails; does that induce a catastrophe?
  5. #5
    Achievements:
    Join Date
    Sep 2007
    Posts
    6,633
    Points
    34,278
    Level
    45
    Blog Entries
    7
    there are too many types of motors to generalize, you are comparing, but certainly VFD's cost more with variable frequency drive and you get controlled high torque at a wide range of synchronous speeds without gear reduction.
    Cheaper motors may not have servo speed control, but may have variable speed depending on load.
