+ Post New Thread
Results 1 to 5 of 5
  1. #1
    Advanced Member level 3
    Points: 4,550, Level: 15
    PA3040's Avatar
    Join Date
    Aug 2011
    Posts
    832
    Points
    4,550
    Level
    15
    Sound recording chips
    Dear All,
    I need to store some voice in the chip and play back about 10 minutes for temple
    Please advice to make low cost solution
    Following link I found some tablet type solution
    https://www.google.lk/search?biw=106...KQfaeANqdyM%3A
    •   Alt10th July 2016, 19:03
      advertising
  2. #2
    Super Moderator
    Points: 46,805, Level: 52
    Join Date
    Apr 2011
    Minneapolis, Minnesota, USA
    Posts
    11,668
    Points
    46,805
    Level
    52
    Re: Sound recording chips
    To record 10 minutes of speech, you can expect to need 5 to 15 megabytes of storage. The greeting card IC's are not likely to have sufficient memory, nor sound quality.
    A modern handheld digital recording device can do the job.
    Cassette recorders are available, although less common than they used to be.
    •   Alt10th July 2016, 23:11
      advertising
  3. #3
    Super Moderator
    Points: 25,592, Level: 38
    andre_teprom's Avatar
    Join Date
    Nov 2006
    Brazil
    Posts
    7,697
    Points
    25,592
    Level
    38
    Blog Entries
    You should seek recorder modules able to plug external SD/USB memories.
    This would turn your project more flexible with regard to the codec and music itself.
    A cheap MP3 player wouldn't make the job ?
    Part of the world that you live in, You are the part that you're giving ( Renaissance )
    •   Alt10th July 2016, 23:25
      advertising
  4. #4
    Advanced Member level 5
    Points: 13,328, Level: 27
    Join Date
    Nov 2012
    Posts
    2,484
    Points
    13,328
    Level
    27
    Quote Originally Posted by andre_teprom View Post
    A cheap mp3 player wouldn't make the job ?
    I too was wondering the same. Personally I think most cheap mp3 players are quite high quality...
    I do not know what kind of hardware is used by the telephone companies, but their recordings sound horrible...
  5. #5
    PA3040's Avatar
    Join Date
    Aug 2011
    Posts
    832
    Points
    4,550
    Level
    15
    Thanks all
    Cheap MP3 Player may be good solution
