[Moved]: ADS error message while running stimulation
arr_baobao
Full Member level 2
Hi all,
there is a error message pop out when i running my stimulation.
can anyone helps me to understand the error and guide me to fix it?
thanks
Re: ADS error message while running stimulation
"bjt_pkt" is empty.
Hierachy down to it and show me content of it.
"bjt_pkt" is empty.
Hi here you go, is this u what u want to see?
i'm trying the modeling the bjt_pkt sub ciruit.
I'm using the template in ADS to test my bjt_pkt.
so in dc_curve schematic with ADS build in template, i insert the bjt_pkt to test my circuit.
I'm actually following this lab tutorial:
https://www.utdallas.edu/~rmh072000/Site/Software_and_Links_files/3B_lab.pdf
but seem like they are using different ADS version than mine. I'm using ADS 2015. So i can't fully follow the tutorial steps as some setting i couldnt found in my ADS.
I'm trying to use my understanding to complete the tutorial and encounter the failure once i start to stimulate.
TOP UP SNAPSHOT design Hierachy .
Maybe this is the snapshot you requested for....
I'm using ADS 2015.
Database structures are different between ADS2009 and ADS2015.
ADS2015 adopts OpenAccess Database structure which is standard in EDA industry.
For example, Cadence dfII after IC6 also adopts OpenAccess Database.
Rename "bjt_pkg" to "schematic".
Cell "bjt_pkt" must have both "schematic" and "symbol" views.
    V
