+ Post New Thread
Page 1 of 6 1 2 3 ... LastLast
Results 1 to 20 of 109
  1. #1
    Newbie level 6
    Points: 1,513, Level: 8
    Join Date
    Apr 2005
    Beijing, China
    Posts
    13
    Points
    1,513
    Level
    8
    USB Blaster download cable design
    hi,
    I want to make a usb blaster download cable for Altera FPGA. Could you please give me some suggestions or schematic? Thanks.
    air2008
  2. #2
    Full Member level 6
    Points: 6,614, Level: 19
    Join Date
    Mar 2002
    Australia
    Posts
    386
    Points
    6,614
    Level
    19
    usb blaster schematic
    Hello air2008,
    The attached pdf is the schematic of the Nios II Evaluation Kit 1C12 from Altera. Page 11 shows the schematic of the USB Blaster. But the programming file for the used CPLD is not free! So I think you have to buy the cable from Altera.
    Bye,
    cube007
    1 members found this post helpful.
  3. #3
    Newbie level 6
    Join Date
    Apr 2005
    Beijing, China
    Posts
    13
    Points
    1,513
    Level
    8
    usb-blaster
    hi,
    Thanks for your help. Anyhow, I decide to design a usb blaster by myself.
    I noted that the Altera usb blaster used usb+cpld to configure fpga. It is important that it adopts the JTAG model but not the PS model to configure FPGA. So, I have to make clear that how do write the cpld code to make the blaster works well with Quatus.
    •   Alt7th April 2005, 08:12
      advertising
  4. #4
    Full Member level 6
    Join Date
    Mar 2002
    Australia
    Posts
    386
    Points
    6,614
    Level
    19
    usbblaster
    Hello air2008,
    That’s a good project. I think there are some people in the forum which are interested in a self made USB Blaster. Let us know if you have some new information.
    Good luck,
    cube007
  5. #5
    Advanced Member level 2
    Points: 11,112, Level: 25
    Join Date
    Oct 2004
    Nice, France
    Posts
    589
    Points
    11,112
    Level
    25
    usb blaster clone
    This is very interesting indeed. I have made a board very simmilar to this, but with a Xilinx XC9536/XC9572 instead.
    I would love to make a use of this board as a USB downloader bor Altera and Xilinx. I have put it on the side due to my recent move and new job, but it would be interesting to see what you make out of your project.
    And thanks for the schematic of the NIOS II, page 11 is almost a copy o what I have ony my board.
    BR,
    /Farhad
  6. #6
    Newbie level 6
    Join Date
    Apr 2005
    Beijing, China
    Posts
    13
    Points
    1,513
    Level
    8
    lattice usb download cable
    farhada:
    I have finished the board desing in Protel 99se. However, I am now puzzled with the HDL code design for the CPLD in the USB blaster. Could you please give me some suggestions?
    air2008
    air2008@gmail.com
  7. #7
    Join Date
    Oct 2004
    Nice, France
    Posts
    589
    Points
    11,112
    Level
    25
    diy usb blaster
    Actually that is where the challenge is. The HW part is the easiest part, to make the unit act like a USB blaster is the most difficult of them all.
    Also, you need to read the content of the EPROM of the flash memory on the USB blaster, the one that is connected to the FTDI chip, put logic analyzer in between the USB chip and the CPLD and capture the communication for a while, do that a few times and you may find a pattern of commands/logic between the 2. That is the only way I can thing of making the USB blaster compatible deivce, uless you have a way to read back the content of the CPLD on the Altera board and cack it :)
    If you don't have access to a logic analyezer, then it is a much much more difficult task. You maybe able to put a SW deugger to capture the data sent to the FTDI driver on the PC (I doubt Altera uses the stadard FTDI driver thought).
    Just my 2c,
    /Farhad
  8. #8
    Junior Member level 3
    Points: 3,169, Level: 13
    Join Date
    Oct 2001
    poland
    Posts
    31
    Points
    3,169
    Level
    13
    usb-blaster clone
    After disasm usb blaster driver - file jtag_hw_usb-blaster.dll some infos are found:
    ftdi direct driver ftd2xx.dll called.
    Possible device ID's :
    VID_09FB&PID_6001
    VID_09FB&PID_6002
    VID_09FB&PID_6003
    Ftdi serial EEPROM (after config info) contain blaster revision number.
    Driver checked this number when staring.
    Only thys function from ftd2xx.dll are used- Ft_read, Ft_write, Ft_setusbparam.
    Packet length is changed dinamically Ft_setusbparam then only
    ft245B are used, 245А is not supported. Bit-bang not used.
    Can anibody sniff usb traffic by Bushound or other utilities? It is possible to find version of ftd2xx.dll with debug printing included?
    •   Alt10th April 2005, 19:22
      advertising
  9. #9
    Newbie level 6
    Join Date
    Apr 2005
    Beijing, China
    Posts
    13
    Points
    1,513
    Level
    8
    usb blaster epm3128 code
    khach,
    The Ftdi is just like the cypress usb develop board, where its EEPROM contains the revision number, although the former is more easy to use than the latter.
    Added after 3 minutes:
    Farhad,
    Thanks for your suggestions. There is a logic analyzer in my lab and I will try to capture the communication between the usb and cpld.
    You said you have made a usb blaster for xilinx. How did you design the hdl codes in cpld?
    air
    air2008@gmail.com
  10. #10
    Join Date
    Oct 2004
    Nice, France
    Posts
    589
    Points
    11,112
    Level
    25
    usb blaster driver download
    Quote Originally Posted by air2008
    khach,
    Farhad,
    air
    air2008@gmail.com
    Actually, this one of the million half done projects that I have done. This one I want to come back to soon after I have my workshop set up again (I have moved 8 times in the past 3 years to/from 4 countries! :0 ) so this time I am not planning to move for a while and will be able to finish some of the projects.
    I started working on the code, but I gave up after the first round of work. I mannaged to work with the FTDI driver and send/receive data to/from the CPLDs. The CPLD was programmed in VHDL (very simmple code, just a simple state machine to controll the Read/Write sequence and timing), all the boards/ewquipments is now on its way from Ireland to France and hopefully I will have them soon and will be able to "play" with them again. I will be more than happy to share the ideas/files with others here.
    BR,
    /Farhad
    •   Alt11th April 2005, 09:29
      advertising
  11. #11
    Join Date
    Oct 2001
    poland
    Posts
    31
    Points
    3,169
    Level
    13
    usb blaster circuit
    For correct reengeneering VHDL code for any CPLD version (Xilinx or Altera) some
    tests need.
    Is one transaction wrom FTDI to CPLD (one #RD pulse) produse only one transition on TCK line? Or one pulse on TCK? Or many pulses ( data from usb are serialized in CPLD)?
    Can anybody check by oscilloscope this?
    How many 24MHz clock periods contain in one TCK pulse ( CPLD state mashine counter size)?
  12. #12
    Newbie level 6
    Join Date
    Apr 2005
    Beijing, China
    Posts
    13
    Points
    1,513
    Level
    8
    usb-blaster download cable
    Hello,
    I have known how to designing the CPLD based on PS mode. I write a programmer utility to download the *.rbf file to the FTDI usb chip and the CPLD send the RBF bitstream according to the PS mode.
    However, it could't be transparently compatible with Altera's Quatus 2. How to design the CPLD in order to let the blastercompatible with Quatus without the need to write our own programmer utility?
    air2008
    air2008@gmail.com
  13. #13
    Join Date
    Oct 2004
    Nice, France
    Posts
    589
    Points
    11,112
    Level
    25
    terasic blaster usb drivers
    There are some minir issues here that you need to consider.
    Hello,
    First of all, RBF based on Altera's programming book (http://www.altera.com/literature/hb/cfg/cfg_cf52007.pdf) is just for Cyclone and other FPGA devices. For CPLDs, I don't think you can create an RBF file, but I maybe wrong.
    However, it could't be transparently compatible with @ltera's Quatus 2. How to design the CPLD in order to let the blastercompatible with Quatus without the need to write our own programmer utility?
    air2008
    air2008@gmail.com
    Designing the code, if you know what you want to do is pretty straight forward. You either write it in a highlevel language like verilog or VHDL (in the case of Altera, you can write it in AHDL) or you make a schematic of the design using the internal logic blocks and then compile and create your POF or JED file.
    Altera has a very good tutorial that comes with the free versoin of the Quartus that you can use to create your code.
    For downloading, I would say it will be easier to use a ByteBlaster compatible device and don't worry much about being able to re-program the device via USB. Specially since this device will be the one used for those kind of tasks and don't need to be re-programmed that often.
    BR,
    /Farhad
  14. #14
    Join Date
    Oct 2004
    Nice, France
    Posts
    589
    Points
    11,112
    Level
    25
    usb blaster cpld
    I know this is an old one, but any new about your idea? Did you spend any more time on it?
    BR,
    /Farhad
  15. #15
    Full Member level 4
    Points: 4,738, Level: 16
    leonqin's Avatar
    Join Date
    Nov 2001
    China
    Posts
    238
    Points
    4,738
    Level
    16
    usb blaster virtual com port
    the key IS the Logic in EMP7064,who has * it?
    It was said that somebody in China has done it well.
  16. #16
    Join Date
    Oct 2004
    Nice, France
    Posts
    589
    Points
    11,112
    Level
    25
    There are a few issues to deal with the USB downloader for CPLDs and FPGAs. The main problem is to make it compatible with the design from Altera.
    I would really like to know if anyone has done anything similar to it and want to work together to fix it.
    Cheers,
    /Farhad
  17. #17
    Newbie level 2
    Points: 1,322, Level: 8
    Join Date
    Aug 2005
    Posts
    Points
    1,322
    Level
    8
    usb blaster driver dll
    I have take a picture of the board, through analyze, I think clone the CPLD maybe possible, but difficult to do. A logic analyzer is absolutely necessary. Try to replace the 24MHz crystal with a lower one, it may be helpful to capture and analyze the signals on it's i/o pins.
  18. #18
    Newbie level 6
    Points: 4,780, Level: 16
    Join Date
    Mar 2002
    Posts
    12
    Points
    4,780
    Level
    16
    master blaster usb firmware
    USB blaster board picture
  19. #19
    Join Date
    Oct 2004
    Nice, France
    Posts
    589
    Points
    11,112
    Level
    25
    make a usb_blaster
    Hi Cluck,
    Thanks for the picutre.
    I have now both a FTDI and a rather large CPLD board, I may have some time to work on the design but it is difficult to make it compatible with the Altera device if I don't know the communication protocole.
    Anyone want to share knowledge, send me PM and I give you my contact.
    Best regards,
    /Farhad
    •   Alt25th October 2005, 13:25
      advertising
  20. #20
    Join Date
    Oct 2001
    poland
    Posts
    31
    Points
    3,169
    Level
    13
    usb blaster driver
    VID/PID
    09FB/6001 - USB Blaster
    09FB/6002 - Cubic Cyclonium
    09FB/6003 - Altera NIOS II Eval Board
    Protocol looks a little similar to Altera BitBlaster protocol, differences full 8 bits are used.
    0000 0000 NOP? *64 used to ensure the bit output buffer is empty
    0001 xxxx ?
    0e1z 11sc Set outputs c=TCK, s=TMS
    e TDO ECHO bit (0= no echo)
    z Tristate ?
    D0 - TCK
    D1 - TMS
    D4 - Tristate outputs?
    D5 - LED
    If D7 = "0", then D4 eq JTAG TDI
    D2, D3 - NCE, NCS ???.
