Can I use xilinx's zynq design block in the simvision?
u24c02
Advanced Member level 1
Hi.
I'm newbie about zynq.
Now I'm trying to simulation in the simvision with simple counter which is made by xilinx zynq.
As I know, basically the zynq have consisted with vary IP. But espcially, basic IP is 'ZYNQ proceszing System' and interconnection by AXI.
Actually I'm not familiar with this simulation tool of xilinx's zynq.
So I'd like to simulation in the simvision.
And I fiund some methods to use simvision with zynq.
But as I know the zhnq are consisted by PL and PS.
And what if I generated the gate netlist form zynq then I simulated in simvision.
Then should I have to program about the firmware? Or just can I verify my system without firmware?
What if I want to verify my system wthout zynq processing unit, what am i supposed to do that?
As long as the necessary libraries are present, netlist sim can be done in simvision.
Use Xilinx SDK.
Only you can asnwer that, we don't know ur system.
Write a testbench.
Read all the related documents from Xilinx, you'll get most of ur answers.
