+ Post New Thread
Results 1 to 8 of 8
  1. #1
    Member level 2
    Points: 1,320, Level: 8
    Join Date
    Feb 2011
    Posts
    45
    Points
    1,320
    Level
    8
    How to measure linear acceleration?
    Hi!
    We know that accelerometer measure acceleration due to motion and gravity? The question is how we can obtain acceleration measurement due to motion alone?
    •   Alt15th June 2016, 17:00
      advertising
  2. #2
    Advanced Member level 5
    Points: 19,994, Level: 34
    barry's Avatar
    Join Date
    Mar 2005
    California, USA
    Posts
    3,853
    Points
    19,994
    Level
    34
    Re: How to measure linear acceleration?
    You mount your accelerometer along the axis of motion, or buy a mult-axis accelerometer. If you do the most basic of searches you'll find accelerometers that do what you want. Try searching "accelerometers".
  3. #3
    Super Moderator
    Points: 28,167, Level: 40
    ads-ee's Avatar
    Join Date
    Sep 2013
    USA
    Posts
    6,440
    Points
    28,167
    Level
    40
    A quick review of the wiki pages on both motion sensing and accelerometers yields that accelerometers make somewhat poor motion sensing devices, as they measure acceleration only not motion.
    e.g. if you have an object that moves at a constant velocity in a direction that is perpendicular to gravity an accelerometer won't sense it's motion as there is no acceleration on the sensor. This is why an accelerometer in free fall measures 0.
    •   Alt15th June 2016, 18:50
      advertising
  4. #4
    Member level 2
    Join Date
    Feb 2011
    Posts
    45
    Points
    1,320
    Level
    8
    Quote Originally Posted by barry View Post
    Thank you barry for your response. I do have accelerometer (I have 10 DOF IMU from DF robot). But the problem is does it really represents acceleration due to motion? Or acceleration due to motion + gravity acceleration?
  5. #5
    barry's Avatar
    Join Date
    Mar 2005
    California, USA
    Posts
    3,853
    Points
    19,994
    Level
    34
    I would suggest you look at the data sheet for both the DF Robot part and the ADXL345 which it's based on. Usually with a 3-axis device like this you orient one axis (say, Z) along the gravity direction. Sometimes the device automatically compensates for gravity so that when it's mounted this way, the x and y axis outputs are zero at rest. If not, then you'll have to calibrate out the gravity term.
    1 members found this post helpful.
  6. #6
    Member level 2
    Join Date
    Feb 2011
    Posts
    45
    Points
    1,320
    Level
    8
    Thank you barry. I will study on this. For now, this is what i have from the IMU:
    X: -0.16 Y: -0.59 Z: 8.67 m/s^2
    X: -0.20 Y: -0.55 Z: 8.63 m/s^2
    X: -0.12 Y: -0.59 Z: 8.63 m/s^2
    X: -0.16 Y: -0.55 Z: 8.63 m/s^2
    X: -0.16 Y: -0.59 Z: 8.63 m/s^2
    X: -0.08 Y: -0.55 Z: 8.63 m/s^2
    X: -0.16 Y: -0.55 Z: 8.59 m/s^2
    X: -0.12 Y: -0.59 Z: 8.67 m/s^2
    X: -0.16 Y: -0.55 Z: 8.55 m/s^2
    X: -0.16 Y: -0.59 Z: 8.59 m/s^2
    X: -0.12 Y: -0.63 Z: 8.67 m/s^2
    X: -0.12 Y: -0.63 Z: 8.55 m/s^2
    X: -0.20 Y: -0.55 Z: 8.59 m/s^2
    X: -0.12 Y: -0.59 Z: 8.59 m/s^2
    But I'm not really sure why the z is not ~9.81 m/s. I will look in this matter also.
    Thank you again.
  7. #7
    barry's Avatar
    Join Date
    Mar 2005
    California, USA
    Posts
    3,853
    Points
    19,994
    Level
    34
    My first guess would be that you don't have your device mounted exactly perpendicular to the earth. That would explain the values you are seeing.
    •   Alt15th June 2016, 21:49
      advertising
  8. #8
    Member level 2
    Join Date
    Feb 2011
    Posts
    45
    Points
    1,320
    Level
    8
    Yes, you are right..it is due to sensor orientation. Thank you.
