+ Post New Thread
Results 1 to 2 of 2
  1. #1
    Newbie level 2
    Points: 35, Level: 1
    Join Date
    Jun 2016
    Posts
    Points
    35
    Level
    RJ45 Modbus cable to D9 connector
    Hi people,
    I have a stripped RJ45 cable to whom i need know how to make the wire connection in a D9 connector, in order to match the pinout of a MPI-Bus adapter.
    How should i connect the wires from the RJ45 cable to the D9 connector?
    Thank you in advance,
    Boardwalk
    Click image for larger version.
Name:	d9 connector.png
Name:	mpi-bus adapter.png
Name:	pinou adapter.png
Name:	rj45 cable.png
    •   Alt6th June 2016, 02:17
      advertising
  2. #2
    Super Moderator
    Points: 46,819, Level: 52
    Join Date
    Apr 2011
    Minneapolis, Minnesota, USA
    Posts
    11,670
    Points
    46,819
    Level
    52
    Re: RJ45 Modbus cable to D9 connector
    Are you certain you need all wires connected? Can you get by with 2 wires sending data? (Ground & Tx)
    Or 3 wires forming a null modem? (Ground, Tx, Rx) It doesn't give you the handshaking, but it's easy.
    If you need functions on all wires, then you must identify the purpose of all pins coming from your two devices. You must match them one-to-one. It may not be an easy taske. The manufacturers do not always give sufficient information to make it easy.
    Here are some pinouts found via internet search. I'll bet they're all different.
