minhducpham2009@gmail.com
Newbie
I have designed an active bridge rectifier (see attached figure), with 4 Switch
The circuit rectifies an AC input signal (110VAC) to 200VDC Output
My question is related to the calculation of the power efficiency (n=Pout/Pin) of the rectifier :
The output power is Pout=Idc_out* Vdc_out
The input power is Pin=rms(Iin(t)*Vin(t)).
IN my simulation : I out 2A * 200V(DC) = 400W
and for the input I_in 7.26A( almost sin - because active rectifier) *110V(AC) = 798.6
So the efficiency is appro.. 50% . And I wonder how about 50 % dissipated or I using wrong calculation
Thank you so much
Thank you so much
