[moved] PCB finish for High Speed pcb
senilicus
Full Member level 5
Amsterdam / The Netherlands
Hello all,
At the moment I am working on a design that carries several high speed signals, (40Mbit, 10Mbit). There is no soldermask on these traces and
we need a finish for those traces.
ENIG or ENIPIG are not possible because of the nickel and immersion silver wil oxidate over time.
One of the possible finishes could be Electroless Palladium/Autocatalytic Gold (EPAG, EPIG)) but this appears to be a finish that not much
pcb manufacturers offer.
Any suggestions?
What a mistake I made.
The signals are 40Gbit an 10Gbit. a bit faster.
Hello all,
Any suggestions?
Hello all,
Any suggestions?
It's best to avoid microstrip transmission lines for 40 Gbps applications. Use stripline transmission lines. Then you don't need to worry about surface finish.
