Re: what is the typical read/write time of ram in ASIC and F
Read and write timings of embeded SRAM depends on the following parameters
- is it High Density or High Speed ?
many parameters.
- technology - 18um,13um,90nm,65nm
- quantity of bits in required memory
For high speed memories clock bandwidth started from 500MHz to 1GHz for 90nm.
