+ Post New Thread
Results 1 to 6 of 6
  1. #1
    Newbie level 6
    Points: 936, Level: 6
    Join Date
    Sep 2011
    Posts
    12
    Points
    936
    Level
    can't delete hard disk
    Hello
    I can't delete hard disk
    In "disk management" I am on the disk I want to delete with right click I see all options and the "delete" option is not active (gray color)
    note:
    * It is a striped hard disk that is one hard disk from 3 actual hard disks
    * the disk is totally empty
    Arie
    •   Alt4th May 2016, 14:07
      advertising
  2. #2
    Super Moderator
    Points: 28,167, Level: 40
    ads-ee's Avatar
    Join Date
    Sep 2013
    USA
    Posts
    6,442
    Points
    28,167
    Level
    40
    Re: can't delete hard disk
    I could be wrong but raid arrays can only allow deleting of all thee disks together. Especially as stripped arrays are considered a single continous disk.
    •   Alt4th May 2016, 14:14
      advertising
  3. #3
    Newbie level 6
    Join Date
    Sep 2011
    Posts
    12
    Points
    936
    Level
    Yes, I want to delete all 3 of them (that are united in one volume)
    •   Alt4th May 2016, 14:26
      advertising
  4. #4
    Full Member level 4
    Points: 1,866, Level: 10
    xenos's Avatar
    Join Date
    May 2015
    Posts
    212
    Points
    1,866
    Level
    10
    First, you have to delete the dynamic volume.
    https://www.microsoft.com/resources/....mspx?mfr=true
  5. #5
    Newbie level 6
    Join Date
    Sep 2011
    Posts
    12
    Points
    936
    Level
    I know it and this is the problem
    as mention in the link at microsoft you sent
    Option 1: Using the Windows interface:
    I did: Computer Management (Local) > Storage > Disk Management, Right-click the dynamic volume you want to delete, and then click Delete Volume
    the problem: the "delete volume" is not active
    2) Using a command line:
    I did: in the DISKPART prompt -->, type:list volume, type: select volume n, At the DISKPART prompt, type: delete volume
    the problem: "Virtual Disk Service error: Delete is not allowed on the current boot, system, pagefile, crashdump or hidernation volium"
    Arie
    •   Alt4th May 2016, 15:29
      advertising
  6. #6
    Full Member level 4
    xenos's Avatar
    Join Date
    May 2015
    Posts
    212
    Points
    1,866
    Level
    10
    The volume is in use (as the DISKPART reported).
    Try removing any drive letters associated with the volume.
    Try starting in safe mode, or in repair mode (console mode).
    If the volume consists of 3 different disks and you do not have anything to save in them, why don't you physically (or by bios settings) remove one to break the volume and then initialize them separately?
